List of Speakers that Fit
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
22OBX
22OBX
Hartford, AL
Where did you mount the AudioControl LC7i? I'm looking at a similar set up from my local installer.
Here is one option that I used for if you have that option.
Ford Bronco List of Speakers that Fit IMG_5558
Oldhippie
Barry
Santa Cruz, Calif.
Kicker CSC44, CSC65, 48CWR84, Key200.4, Key500.1 plus Jensen JA2B. Good enough for my old deaf ears….
KABQ
Aaron
Albuquerque, NM
Kicker KS Series hit the kick panel grilles with protruding tweeter, but just barely and they can be reattached no problem. Makes them buzz like crazy, though.
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Probably not. I'm using the Ford Sub Delete for subwoofer and amp. Might be too big against panel. I'm having pro installer complete this portion of install with wiring. Curious on options.
22OBX
22OBX
Hartford, AL
Gotcha , the panel I have is mounted where the factory sub goes. It has the LCI7 , the Kicker mono amp, and on the back side the Kicker key. All in one place. You could mount the LCI7 in the storage under the floor.
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
Infinity Reference 407F - 3 across dash and pair in roll bar pods direct fit.
Memphis MJP6 - Kick Panels, Metra mounting adapters - require drilling into adapter to get wire into place
Kicker Comp R 8" Subwoofer - Requires minor trimming of a centering tab on the bottom area of B&O enclosure - so speaker sits flush (opening is proper size) Also requires drilling new mounting screw holes and modification or swap out of wiring harness. Also requires removal or trimming of "Kicker" beauty ring on speaker perimeter - tedious but easy enough to do.
Polyfill and Dynamat/Kilmat all around.
