Low speed squeal
mike12779
2017 Grand Cherokee Trailhawk
I now have about ~2k miles on my Bronco (2.7/Badlands) and recently noticed a very low (at least to me) squeal when I am at low speeds. This only seems to happen if I have been driving for a while. If I just drive around after it has been sitting for a while, the noise is not immediately there. I can put it in neutral and rev the engine, the noise is not there. It just is present when moving, and may not necessarily only be when it is slow, that is just the time where I hear it.
You can easily hear it in the video, the noise is not specifically coming from the left side, I just had the phone out the window to capture the noise.
Any help would be apprecriated, I only want to go to the dealer if I have to.
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
Sounds like a small rock stuck between the rotor and the backing plate/heat shield.
North7
North Texas
SUV
Check for the loose hose clamp problem or the harness rubbing on the belt/pully problem.
lasttj
Robert
'06 Jeep TJ, '16 Ford F150, '65 VW Beetle
Sounds like a trip to the dealer is in your future. Sorry.
Jrl
Pittsburgh,pa
Bronco sport ,first edition C.G
Plate rub . Something bent the plate into the rotor .
mike12779
Belts would always be moving right? This stops when the vehicle stops.
Lifeliberty
Moonbeam👀
Columbus, OH
Possibly Brake rotor/low pad gauge could be hitting wierd or
Wheel bearings.
mike12779
Just an update. I went under and pulled on each brake shield a bit, nothing seemed abnormal from what I could tell. The same day I took it off-road and I have not heard the noise since. Now it has been about 4 weeks. I have no idea what it was or what exactly fixed it.
2w1se
Jake
Vancouver, wa
Vw atlas
Thanks for the update. This happened to me in my ranger. I got a tiny rock stuck in my rotor never did find it but the noise went away. I noticed mine made more noise when I was turning.
Colt Bronco
Arkansas
I had this issue as well, but on a 2.3L. I only noticed the sound when I was turning into the neighborhood, but it went away on its own after a week or so.
