M190 Front Axle - Largest Tires it can handle?
StachioAttack72
Paul
Connecticut
Bronco 4 Door Outer Banks
I’ve searched high and low, and can’t really find a definitive answer on if putting 35’s (ie: as close as possible to 35’s with crash bar removal) on a non-sas model Bronco (mine will be a 2.3L OBX) would break the M190 axle in anything beyond running on smooth roads.
Not that I’d take my Bronco off reading, but just investigating the possibilities as I’ve seen others on here put 305/70/18’s and 285/75/18’s on the stock OBX’ wheels. Not sure if it could lead to busted axels in the future.
Thoughts?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
So the weak link doesn't seem to be the axles themselves, instead it seems to be the tie rods.
You should be able to do 35s without a problem unless you are really beating your Bronco against the rocks. 37s are probably in the "iffy" zone. Any higher than that and you better prepare your wallet for abuse.
Also... I don't know what axle ratio you picked up, but if you got one of the lower ratios, your Bronco will probably act a little on the sluggish side the larger tire you get.
StachioAttack72
StachioAttack72
Paul
Connecticut
I got the 3.73 Open Style Rear Axle Final Drive Ratio.
(Yep… I know I’m a noob)
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
Definitely street, not really going to murder it in off-roading. Saving that for my Wildtrak.
i think it will be MEH on 35s with 3.73 but i dont think you will kill the front diff from street use.
Oldhippie
Barry
Santa Cruz, Calif.
Ford didn’t do it for a reason...if it does break don’t expect warranty...start spinning on the snow/ice and catch traction = snap...
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
Wonder what the definition of "you should be fine" really is? You could drive your Bronco with 35's for it's entire life and not break anything, or you could decide to jam down a dirt road and hit a fun looking spot and break the thing next time out. 35's are on the edge for that axle, just be careful. Or, forget how you want it to look and stick with 33's and then don't worry about it.
