Metal Noise over bumps from front end
Adam shib
Adam
Israel
every time i drive offroading or over some pumps i hear this annoying noise from the front end like something loosing but there is nothing there loosing, I attached video for the noise, my dealer cant find the problem… anyone face similar issue and resolve it
Raptor911
Raptor911
Broadlands, VA
1 - Def sounds like something is loose
2 - why does everyone post in the Raptor section when they don't have a Raptor?
VIRUS
D
Wisconsin
Truck, car, feet
Sounds like the prop-rod for the hood
Or many other things 😆
Adam shib
Adam shib
Adam
Israel
Sorry i didnt post it in Raptor section, but it moved automatically here.
there is nothing loosing down there, i check it multi times also the dealer
Adam shib
Adam shib
Adam
Israel
another video for the clunck noise
Adam shib
Adam shib
Adam
Israel
Like which things i need to check? Its drive me crazy !!
also it seems like the noise come from between the center and the front end, and i hear it specially while driving on road with small holes
Grumpy
Who's
On a Lake
22 2dr
Sounds to me like the 3 nuts on top plate of front coil overs are loose. I wouldn't be surprised if dealer didn't see it or know about it as the top plate is obstructed and usually won't move if at rest since they are under load. And I usually don't take dealers word on shit when they say all is well. Only when the springs are expanded or compressed will this happen. You need to push away on the front fender liner and take a wrench to each nut and check for any being loose.
Adam shib
Adam shib
Adam
Israel
Thanks for your responding, what you said makes sense, since I did a lot of tests on all the parts below, I was sure that maybe the cause of the noise is something hidden that i cant see.
do u know how i can see the 3 nuts on the top of the coil plate? Or where it located, do u have maybe photo for it ?
gmannerino
Glenn
Austin, Texas
1994 Isuzu Trooper
After going in for an oil change and tire rotation yesterday and I believe I now have this issue, too.
I was hoping it was something loose on the skid plate, but I went under and all components seem tightened.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there. I can look into your Bronco’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
Jro
Guest
I have found that the front skid plate on some Broncos can be making contact with the bumper. Thump the skid plate with your fist and you will know right away.
Then just loosen the skid plate and adjust fit
gmannerino
Glenn
Austin, Texas
1994 Isuzu Trooper
Ah yeah, removing the skid plate and re-bolting it did the trick.
  • Like
Reactions: Jro
dgorsett
colorado
F250, Mustang, Explorer
Ha Ha. I drove mine for a day after 5100 install and had the noise on bumps. Checked top hat nuts, left front finger tight. Apparently, my son and I each thought that was the other guys job on our team install
blueoval16
Marcus
St.louis
6G Bronco
Did you ever figure out what this was? I have the same issue. I've checked and tightened all components that I can get to including the top of the coil over and still have this noise. On flat ground if i turn the wheel back and fourth I get that noise as well.
vb_bronco
Drew
Virginia Beach, VA
2022 Wildtrak
Same, also curious for an update.
