ChrisD
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
Pay you don't live ever they use a lot of salt on the roads looks like your frame will last about 2 years
Northern Utah, plenty of salt.
ChrisD
ChrisD
Ugh looks like lots of winter car washes
Haha, yeah, I have a subscription to the drive thru car wash that sprays out the undercarriage. I'd never even known about subscriptions to car washes until I got to Utah. :)
MTNLUV
Idaho
2022 Badlands 2024 Wildtrak
How well do the soft tops do in a car wash?
lakesinai
Charleston SC
I joined with a local offroad club, Wasatch Outlaw Wheelers, on Saturday for a trip up to Miller Hill and MIneral Basin.
It was mostly rocks, rocks and more rocks. When there weren't enough rocks, there were more rocks. Everyone was curious about the Bronco going up. For most, it was the first one they'd seen. They're pretty scarce still.
A few notes:
1 pedal drive will get the brakes really hot. I much prefer to put it in M , set it to 1st gear, and just roll along until an obstacle. It seemed really happy that way.
I think I'd have cleared things a lot better with the leveling kit. I'm definitely on board with getting it up a bit higher and I regret not ordering Sasquatch.
The vehicle is capable. The only times I failed to clear an obstacle was because I high centered. One or two more inches of ground clearance would have likely been plenty.
I now know exactly what hangs up on the Bronco as you're going over obstacles. I have photos to prove it! Also my embarrassing video of getting high centered!
The rock rails did okay. Frame mounted ones would be better, but the stock ones worked.
Woah! Looks like the standard Badlands is the wrong car for those loose rocks/boulders on a dirt trail! And the undercarriage already looks 6 years old, bent steel with flaking paint! I think you're correct, the Sasquatch is the trim for those trails!
ChrisD
ChrisD
Seemed to do fine the other day. It was noisy and I was apprehensive, but I pulled out the other end and everything was just fine. It seems really secure when it's properly assembled.
Also, the company we do our car washes with opened a new location close to our house and they're having problems with the machinery. We got stopped in the middle of it the other day in the wife's Lincoln.
johndeerefarmer
'17 F150, '20 F350 Powerstroke
A few notes:
Yeah, you add 2" of clearance and then you will drag on other taller obstacles.. Then you will want to add another 2" and so on and so on........
ChrisD
ChrisD
Nice ride! Those edges should have been rolled over anyways.
I'm figuring if I get under there with some Rust-O-Leum, it'll look like new! Haha!
If those parts get bad enough, they're just supports and can be cut out and new welded back in. They're not load bearing, just stabilizing.
LostInArizona
Brandon
2022 Badlands non-sas 2.7
... this Bronco is going to cost me an arm and a leg when it's all over!!! 🙃
There is where you are wrong.... It will NEVER be over! What other body parts are you willing to give up? :ROFLMAO:
ChrisD
ChrisD
Note to self: If ever buying a used Bronco, take a look underneath for frame damage! :oops:
Yep, that's for any 4X4.
In this case, it's not the frame, though. It's the transmission support and it's a part you can unbolt and replace.
Here's a photo of a Bronco frame I annotated to show you the part in question:
Ford Bronco Miller Hill / Mineral Basin UT trip in my Badlands check-out-the-bare-bones-2021-ford-bronco-showing-frame-chassis-and-suspension_3
Broncolli
MD
'21 Back Diamond 4 door MIC
There was video comparing wildtrack suspension with a base suspension, in that video they took the soft top Wildtrack through a regular car wash.
goatman
Richard
Bakersfield
A bunch of Jeeps
Why I will only get a 2dr. But yes, makes a good case for a Sasquatch. I'm still going back and forth in my mind about non-SAS BL or Basesquatch. Gotta see if 4WP is actually going to come out with their disco sway bar for the Bronco and if it's any good.
As with Jeeps, we'll find out pretty quickly what we need to beef up underneath the Bronco. This trip, report, and pics are a very good start. Much thanks to the OP.
