- Sean
- Jul 1, 2021
- 7
- 252
- 1,116
- Las Vegas, NV
- Wrangler JL. Land Rover Discovery Sport
- Undecided
I do call into question only 'airing down' to 30psi - what's the point? Need to drop to at least 20psi to make a difference. And I think it would have helped the Bronco more in increased traction.
The thing is, every 'disparagement' in the article of the Bronco has been posted in this forum. It's pretty accurate.
The window rattle has been described in detail here:
https://www.bronco6g.com/forum/threads/violent-window-rattle.25251/
And the difficulty to climb relatively easy obstacles without lockers has been covered as well:
Hopefully the off road traction control will get tweaked to perform better. But for now, you really need lockers in the Bronco. Both Jeep and Toyota have a separate system when in 4L that operates differently from standard TC and makes the need for lockers much less.
As for pavement feel, well, it is really subjective. I love how my 2 door JL drives. I do 75 - 80 on the freeway everyday and its solid as a rock. I prefer it to my wife's Land Rover as it feels more alive and connected. But, we have great, smooth roads, if I had to drive on some of those eastern highways, with heavy expansion joints every 20 feet, I would absolutely favor something with a more forgiving suspension.
The rest of the stuff is all relative to personal preferences - of which the writer does definitely favor the Wrangler, though he points out, albeit in passing, those opinions are split amongst the testers.
But in the end his conclusion is pretty spot on:
"The Bronco is an excellent Wrangler competitor, but it's no Wrangler killer"
Go back a year and look at all the posts on here about how the Wrangler will be dead once the Bronco hits the street. Hyperbole runs strong in these forums...
