Since there isn't a reasonably priced solution, I trimmed the cheaper set until Rokblokz releases their products. First I held the flap against the extended fender flairs and marked them by dragging a scratch awl along the outline. Once marked I used a sharp utility knife and steady hand to cut the rubber (not confident w/ Dremel and it cut fast). I used the included bolts/clips to attach.
With the rails off, I removed the front endcaps which are secured with a torx screw and plastic push fastener. I determined that cutting 2" from the leading edge would give enough clearance for the mud flaps while still giving adequate rock rail protection. Using a protractor, I determined two angles of 10 degrees need to be cut using a compound miter saw. I have a 14" cutoff saw which is fixed at 90degrees so I opted for the compound miter saw. They dont make a 12" cutoff wheel so I took a chance and used an old carbide tipped blade to make the cuts. In order to make the cuts, I flipped the rail upside down and had to elevate the saw so the rock rail brackets wouldn't be touching the ground and interfering with the cuts. I let the blade do the work with slight pressure and it made great cuts. Then deburred the inside/outside if the rail w/ a file. Using the cut pieces, I laid them on the new leading edge and with a 90degree pick, marked the holes to drill new holes for the torx and push fasteners. I finished it off w/ satin black paint for the cut edges. Prior to reinstalling, I taped off the pinch weld edge, scuffed with fine steel wool and coated with black rubberized undercoating
Next up will be the install of removable steps which are halfway done.
Link to initial rear mud flap install:
https://www.bronco6g.com/forum/thre...-sasquatch-with-side-steps.30544/post-1033099
