Mud Flaps for Badlands (stock rock rails) with Sasquatch
bytheway
Brice
Louisville, KY
Mybbackpacker
Chad
Oklahoma
08 FJ cruiser (just sold), 18 F150 FX4
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I just ordered the Gatorbacks direct from the manufacturer's website. It's more than I really want to spend but almost half of what my dealer is selling the same items for. I was going to make my own brackets similar to what they have(I thought of this before I saw how they are attached) and using generic mudflaps but that would mean working in my garage in the minus cold right now or waiting for three months to do it when it is warmer. I don't want to wait that long. lol
AzGoat
Seattle
2003 Suburban 2500
The Gatorbacks are obviously expensive, BUT they are pretty cool in the way the rubber flap can be removed when wheelin. Very tempting, and it would be great to hear an owners report on how they work on AND off road. My main question is, with the rubber flap part removed, is there any clearance issues to be aware of or worried about?
dcg2
Don
PA
Honda CR-V
So I'm working on a DIY set that utilizes cheap rubber flooring for the flaps themselves. This allows them to be flexible and remain on even when wheeling.
Here are some pictures I took while fitting the fronts.
I ended up using the frame mount for the intrusion bars that aren't used on the sasquatch'd Broncos.
The mount are made from 3/16" thick A36 and are strong as hell. I'm reusing the bolt Ford left threaded into the intrusion bar frame stub. It needs an 18mm wrench BTW.
The "flappy" material is sandwiched between the mounts and a sheet metal backer on top to keep them tight inside the flares.
The very top of the flaps will be bolted to the flares. I used a NutSert mounted to the lowest stiffener inside the flare.
Once both sides are fitted and I'm ready to finalize them, I'll glue the rubber and sheet metal together and everything will be blacked out.
Maybe not the most elegant solution but I'm having fun figuring out the engineering for these.
The backs are much simpler mounts that will bolt to a convenient frame gusset and will be very much like trailer flaps on a semi hanging down from the mount bar.
Waiting on those since i'll need to pull the wheels to drill the gusset and mount the flaps.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
Can someone who buys the Gatorbacks please put the upper section (with the rock rail holes up front, just screw holes out back) on a scanner so we could use it as a template for cutting generic flaps?
Romano
Roman
Portland, Or
Bmw/Honda/Ford
I don't think there are any on the market yet, except the crazy expensive Gatorback ones at $449 for a set of two (!).
I've seen photos where people made some others work by cutting a hole for the rock rails on the front ones. They just used a dremel and I might go that way if nothing shows up at Sema. Not paying almost $900 for mudflaps, no matter how fantastic they might be.
But I'm definitely adding something, the Bronco throws dirt and rocks like it's it's job, I haven't even been more off road than gravel parking lots and driven through puddles and the sides are sprayed with dirt, including the door handles. Plus little rocks hit the rear fender and cause damage. I have little interest in rinsing my car off every day during the rainy season, which is very short here, but still annoys me.
There is at least one other manufacturer working on these for a reasonable price, I just can't remember the name right now, but if you search the forum, they are mentioned in one of the threads about flaps.
Rock Blocks are making flaps for the bronco.
BroncoAZ
Mitch
Seems like RB has been teasing them since October or something. Three months to gear up product development and manufacturing seems excessive for a relatively simple product.
Romano
Roman
Portland, Or
Bmw/Honda/Ford
seems like an extremely simple product. I just started looking into these myself.
KrazeeEyezKilla
UT
Gatorbacks plain black with no logo for $580.00 for complete set (Finally a solution)...just ordered
https://www.sharptruck.com/2021-202...vable-mud-flaps-set-fits-with-rock-rails-only
Are you happy with these? I didn't want a logo so spending less for plain black seems like a win. Just not sure if I should wait to see what RokBlokz puts out...although given we're in the middle of winter here and I have snow and slush freezing up all over my fenders and door handles, not sure I can wait much longer.
araines
araines
Alan
Boca Raton, FL
Porsche 911, Ford Expedition
Install was relatively straight forward (spring clips and trying to get washers lined up were a pain). They look great. I did not install the rears as they do not seam to protect anything beyond rear bumper. (I am likely going to return the rears). Fronts definitely prevent debris and water from being sprayed all over the side of the truck.
AzGoat
Seattle
2003 Suburban 2500
Ford Bronco Mud Flaps for Badlands (stock rock rails) with Sasquatch Flaps 3-1
Looks great - congrats! Quick question: When you remove the rubber section, will the flap part that stays on the vehicle cause any issues while wheelin? Maybe post a pic like the last one you did but just above ground level to get an idea how low the permanent part hangs down? Thanks!
Pseudoko
Vince
Chino, CA
My 2 Feet
haha it protects the car behind you when the tires chuck a rock straight back :D
I have a set of 4 sitting in my garage waiting to be installed. in terms of using the molded mudflaps, there was another thread awhile back where someone had done the cutout with a dremel. you may want to try to search for that thread and ask them how they did it.
