Negative off set on stock Sasquatch tires and suspension
Mlkeyp00
SoCal
23 Bronco Badlands Sasquatch
I’m having the most difficult time picking out wheels for my Badlands Sasquatch. I want to keep the stock tires (315/70/17) and I’m not lifting. I like the deep dish rim look and notice a lot wheels that have negative offset have that look. I’m looking at -18 up to -25 off set (black rhino/ssw) but CANNOT figure out if those wheels will fit without any cutting, trimming etc. Can anyone help? Also post deep dish rims if you got them with any offset neg or pos and keeping stock tire/suspension setup.
contented
Karl
Central Fl
BMW M2 Competition
You might want to watch this video by Quinn of 74 Weld where he talks about wheel offsets and why one should run positive offset wheels.
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
On my 22 Wildtrak, I had 20x10 -18 on 35x12.50's with my stock suspension. With normal on road driving they just touched the running board at full lock and were very close to the wheel well liner. I was able to modify the steps thanks to a post I found on here about swapping them side to side and I installed the JKS kit to give me some room with the wheel well liner and no more problems after that. Not sure why, but for some reason it won't let me attach a pic right now.
Mlkeyp00
SoCal
Cool thank you! 20s tho, I’ll be sticking with 17”
Roost
Cave Creek, AZ
2023 Bronco Wildtrak
I went with 17x9 and -12 offset with stock Wildtrak Sasquatch suspension and stock 315/70/17 Goodyears. Zero rubbing. The half inch wider wheel and the -12mm offset widened out the stance and improved the handling on the road. I went with Fuel Rebels. Hope this info helps!
Mlkeyp00
SoCal
Yes it does thank you! Hey post a pic let’s see it 😍
goodgraf
Dallas
2022 Bronco Badlands
I went with -12 Pro Comp 17x9s with Nitto 35x12.50R17LT Tire. Attached pics with flares and flare delete. About inch or so poke with flares. 3-4 inch poke without flares. I have Icon Stage 3 coilovers adjusted to about 2.5 inch lift. No rubbing.
Ford Bronco Negative off set on stock Sasquatch tires and suspension 1000010602
Ford Bronco Negative off set on stock Sasquatch tires and suspension 1000006591
JL8jeff
Ewing, NJ
I don't know if you want to go -18 or more, that's a lot of poke. I have some Pro Comp 17x9 with -6 and would have preferred 0 offset but they didn't offer 0 in my particular wheel.
Ford Bronco Negative off set on stock Sasquatch tires and suspension My_Bronco1
Ford Bronco Negative off set on stock Sasquatch tires and suspension My_Bronco3
Ford Bronco Negative off set on stock Sasquatch tires and suspension My_Bronco2
Mlkeyp00
SoCal
Copy I’m not really looking for poke I just want a deep dish or lip. If wheels have zero offset or even positive but have deep dish I’m down for that. I just feel like wheels with deep dish had negative offset. But I’m still very very new at this so if anyone has advice for wheels with deep lips/dish and no offset I’d love it!
JL8jeff
Ewing, NJ
Yes, the deep dish look is going to be serious negative offset which won't really work on the Bronco.
Mlkeyp00
SoCal
Yeah I figured! I really like the Black Rhino Stadium wheels. I’m thinking to go with -18 or just zero offset. It seems like people are saying the -18 shouldn’t be an issue to fit. I’m waiting on Black Rhino to send me photographs of the zero and -18 wheels so I can compare the deep dish pizza 🍕
Mlkeyp00
SoCal
Sick!
