- First Name
- Shane
- Joined
- Jun 5, 2024
- Threads
- 9
- Messages
- 75
- Reaction score
- 183
- Location
- Olive Branch, MS
- Website
- www.genesisoffroad.com
- Vehicle(s)
- '21 Bronco
- Your Bronco Model
- First Edition
- Thread starter
- #1
These days everyone wants to use more and more electrical accessories in their vehicles. If you need to plug in a fridge, camping gear, heating blankets, charge your cell phones, tablets, camera and drone batteries, and more, you'll quickly realize you need more power outlets to plug everything in.
Genesis Offroad designed this easy to install Power Box to give you 3 extra outlets in the back of your Bronco. On our website you can choose a 12v power socket, a dual USB charger, or a voltmeter for each of the 3 positions, and we will assemble it to your specs so you get exactly what you need.
Simply secure it in place under 2 factory hard top bolts in the rear cargo area, and route the included 20' long wire harness behind the interior trim, through the firewall and over to the battery.
If you have our dual battery kit installed, then you'll connect the wire harness to the power & ground bus bars - that way everything plugged into the Power Box will run from your second battery and will not drain down your cranking battery. We will be shooting a detailed installation video soon.
If you do not have our dual battery kit installed, you can still connect the wire harness to your stock battery to have constant-on power available. Just be careful and don't drain down your cranking battery!
As of 7/26/24, this product is in production and we expect it to begin shipping by late August. Go ahead and get your order in now to be the first to receive it! Click here to learn more and order - https://www.genesisoffroad.com/bronco-power-box
Note we designed the Power Box in a 2 door Bronco. We don't have access to a 4 door, but we're pretty sure it will fit, just need some help testing it in a 4 door, so here's a special offer - place an order for the Power Box and if it does NOT fit your 4 door, just send us some detailed pictures so we can see what needs to be adjusted. Then we will send you a return shipping label. Once we get it back we will give you a full refund including your shipping charges. If it DOES fit your 4 door, great! Send us some good pictures of it installed for our website, and we will give you a 50% REBATE back to your credit card! This offer is only good until we get confirmation from someone, then we will update this post.
