Newbie question: Advanced 4x4 + 4A…?
DesertEagle1776
Nevada
Old-Timey Bicycle
If you enable the Power Distribution visual on your dash, you can see when power is applied to 2 wheels vs. 4 wheels. I find that 4A engages all 4 wheels at all times of acceleration and cornering. If you're just maintaining freeway speed, power will only be applied to the rear wheels. Give it the slightest touch on the accelerator though and all 4 wheels engage.
4A can be used all the time and at all speeds, and I often forget it on, however, I do try to use it only when roads are wet or if I'm in Sport mode. You can engage and disengage 4A at any speed.
Oh cool, I didn't realize the system was even more active than I thought. Good info.
BillysMom
Jetta
Cascadia
Bronco & some motorcycles
I had an earlier version of this 4A in a body on frame Explorer, its basically really useful in snow, and loose or varied surfaces at higher speeds. I tend to do a bit of spirited driving on curvy roads in anything i can and I found it useful with that truck in those situations too. In a way its like adding something similar to audi/subaru style awd to a traditional 4x4.
It's actually the central feature for me choosing a Sasquatch package, I really wish i could just choose this transfer case on an otherwise base bronco but alas that is not something ford is willing to do at that trim.
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
