Itās got Baja mode instead which is the same but locks the locker. Just disable the locker after popping it into Baja and rip it.Any reason for this?
Why spend money for the 2.7 when "Normal and Eco" gimps the engine......
From preliminary reports, there can only be 7 GOAT modes. Since Badlands has the sway bar disconnect, they added Rock mode and removed Sport mode.Any reason for this?
But if you change it to 2H the Baja mode will disengage and youāre back to āNormalā modeThis topic has been talked about quite a bit...
Baja is the same as Sport but is in 4H. Change it to 2H and you have Sport. Done.
Is that confirmed?But if you change it to 2H the Baja mode will disengage and youāre back to āNormalā mode
No, and neither is what you said. Gotcha!!! ?Is that confirmed?
I wonder what Baja exactly does in this vehicle. Baja in the Raptor turns off abs, traction, keeps the turbos spooled and etc. Not exactly ideal for most street drivers.Itās got Baja mode instead which is the same but locks the locker. Just disable the locker after popping it into Baja and rip it.
Ha! Very true, but I had a Focus RS where you can toggle modes and then traction control, so I know Ford makes it possible for you to toggle pre-selected options when you select modes.No, and neither is what you said. ?
Gotcha!!!
Hopefully it is like the Raptor which automatically puts you in 4H but you can switch it to 2H, the funnest mode to run?Is that confirmed?
https://www.fordservicecontent.com/...e-Supplement-version-1_su-2_EN-US_06_2017.pdfBut if you change it to 2H the Baja mode will disengage and youāre back to āNormalā mode
Baja only works when you are in 4H
Thatās cool. In a Mustang MachE you can drive the car with only battery power.https://www.fordservicecontent.com/...e-Supplement-version-1_su-2_EN-US_06_2017.pdf
On Raptor you can switch the drive mode while staying in the selected terrain mode. Some combinations you can't get like Rock Crawl and 4x2 but most are available.
