Non sas 2.7L badlands w 285 75 17
Reidt131
Reid
Howell, MI
2019 F150,
Would appreciate yours (and everyones) opinion: what do you think would be the max diameter without removing the crash bars? 34 or 35?
I would say 34 is the max. Here is full lock front and rear clearance with 285/75 at base height. Any larger diameter and I would be wondering about mud clearance issues personally.
Ford Bronco Non sas 2.7L badlands w 285 75 17 1000001929
Ford Bronco Non sas 2.7L badlands w 285 75 17 1000001928
Front (second pic) is closer than rear.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I know there someone has this question. I put 285 75 17 on my non sas badlands. Did not remove crash bars- easy have an 1 inch on full articulation. Moves it up to 34s with same width. I had my ko2s on (73k miles) from factory. Wanted k03 because i loved the bfg but that size was not available until August and couldn't wait. Went with Toyo Open country at3. It was only load C available(has e load as well) Smooth n quiet. No issues on the wet road. A little squirrely around 70+ but I'm not sure if it is the tire itself or the height difference, or cross wind as it's been bad. Considered the nitto recon and ko3 in the 285/70 but really wanted to move up. I had the wild peak at 4th and everything else a distant 5th. It is my commuter, beach drive and gets me to the mountains 1 or 2x in the summer. Pictures of Traveler attached
Traveler
Looking at this size for my Badlands. You mentioned KO3 in this size in August. Is this certain and is it going to be a C or an E class tire? Thanks.
JDWeevil
Suburban
My info is off the DT website. It says available in August. E load but the weight for the ko3 was the same as the 285/70 so idk. I was told that depending on your air pressure that you may not know the difference and if they would have been available i would have went w them as I liked my ko2s
*Update on mph I'm 1 mph off under 70 and 2 mph off 70 to about 75. I don't drive really faster than that because of wind noise but seems around 75 it jumps to 3.
Tonka Bronka
Duncansville
Yes that’s odd that the weight is the same. Thanks for the info. I still have some miles to burn on the originals and I’ll keep watching. I have the optional bead lock capable wheels on my badlands and I want to keep them and don’t like any poke so I’ll probably go with this size. Just a tad taller will be good I think. I have the manual trans so gearing should be fine.
Muffin Top
TX
JK, MK, KK, TJ, DN
Here is full lock front clearance with 285/75 at base height.
Looks like more than half an inch of clearance? 255/85R17 ?
Reidt131
Reid
Howell, MI
2019 F150,
@AARDVARK122 has Mickey Thompsons in that size, but it appears he has at least a mild lift.
Ford Bronco Non sas 2.7L badlands w 285 75 17 1000001954
That being said, the difference between the two is less than .3" total or .15" lost clearance, and the 255/85 are narrower so I would guess the clearance would be nearly identical.
Muffin Top
TX
JK, MK, KK, TJ, DN
Awesome, good points, thanks !
Reidt131
Reid
Howell, MI
2019 F150,
One thing worth noting is that the Mickeys are E rating in that size so they will be quite stiff. They were a top pick for me until I realized that, because I don't need an indestructible tire for the trails I drive.
AARDVARK122
john
utah
2007 volvo xc70
Yes I have a black diamond with a 2” rough country level kit. 255/85/17 Baja boss. And rock jock anti rock sway bar. And have no rubbing in full articulation. I don’t drive in much mud out here in Utah. So I can’t speak to the mud clearance.
Muffin Top
TX
JK, MK, KK, TJ, DN
Nice. On my jeep TJ I have an aftermarket front swaybar to improve tire clearance up front, so I'll have to take a close look at that.
Muffin Top
TX
JK, MK, KK, TJ, DN
Just checked, those fancy 18" rims I was enthused about are harder to shop for than 17s.
I guess I could take a chance on 285/75R18. If they're too big (close to 35), then the crash bar(s) are removable.
Muffin Top
TX
JK, MK, KK, TJ, DN
Yoko Geolander A/T GO15
LT295/70R18
Diameter of 34.4" and not a wide tread width.
I discovered this brand for another truck where I wanted pizza cutters. The installer claimed the pizza cutters were too narrow for my rims, so I got exactly the same offroad specs from Yoko's with the higher section width.
