Just curious, if we choose the soft top option for delivery. Will we be able to order a hard top for a 'later delivery'?
That's what my vote would be for. There's also some nice aftermarket soft tops, like a "fastback" one I've seen a couple pictures/videos on, which (IMO) is nicer looking than the factory soft top option.Yea thats what I was concerned about... My dealer initially said best bet was to go with the soft top to have a better chance at the MY21... but thinking now, going to go to the MIC... and get an aftermarket soft top later.
I posted this on another thread, but I screwed up my order and ended up with the soft top. Dealer says they cannot change the order, I can either cancel or let it be built and if I don't want it they will happily sell it. I just found out about the wiring thing so not quite sure what to do. I have a build date of June 21. How about you?Just curious, if we choose the soft top option for delivery. Will we be able to order a hard top for a 'later delivery'?
Can the same be said for the front bumpers? Just curious before I change my WT standard bumper with the built in fog lights.Yes, but if you get a soft top you won't have the setup for rear window washer and the power for the rear window defogger. Ideally you'd order a MIC so it's wired in, and then you can get the modular hardtop later on.
We have not had a specific answer to that question. Recently there was a wiring diagram shared that implied the fog wiring was present irrespective of what bumper is ordered, but considering how the hardtop wiring and plumbing is handled, I wouldn’t count on it.Can the same be said for the front bumpers? Just curious before I change my WT standard bumper with the built in fog lights.
that would be my guess too, also no switch to turn fog lights on on the dashboard or where that switch usually is in a Bronco. To add fogs later on it might be easier and cheaper to wire them to one of the Aux switches.If you order a Bronco from the factory without fogs, I would operate under the assumption that there will be no wiring harness for fogs.
$0.02
So then what is your order, obviously not an accidental soft top! What would you do if you were me, I feel like such an eedjit.I dont have a build date yet.. so I should be 'okay' If not, I'll be okay with it either way...
May just stick with the the standard WT bumper with the fog lights then.We have not had a specific answer to that question. Recently there was a wiring diagram shared that implied the fog wiring was present irrespective of what bumper is ordered, but considering how the hardtop wiring and plumbing is handled, I wouldn’t count on it.
$0.02
