Phones Heating Up While Charging
Tofudude
Chan
22 Brono Base Mansquatch
Does anybody else have an issue with their phones absolutely cooking while being charged (wired)? I've check with both usb ports, front and rear, and the phone always heats up to a point where it stop charging until it cools off.
Ducati1098
I’ve had issues with wireless getting hot, but can’t say I have had issues wired to any of the outlets. What type of phone do you have?
Tofudude
Tofudude
Chan
IPhone 12 mini the SO's iphone as well along with multiple cables including apple cables.
I totally get why wireless charging would heat up but not the wired.
JerryC
Memphis
2022 Bronco
Wireless charging yes. Wired no, but...
On an hours long trip running Android Auto my phone overheated while connected via USB. I think combination of running AA and topping up the charge is what overheated the phone but took about 4 hours.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Yah it's a pretty common problem.
Easy-v
U S A
BadSquatch
https://support.apple.com/en-us/HT208078
  • Your iPhone might get slightly warmer while it charges. To extend the lifespan of your battery, if the battery gets too warm, software might limit charging above 80 percent. Your iPhone will charge again when the temperature drops. Try moving your iPhone and charger to a cooler location.
1. It seems getting 'warm' is a known side effect of wireless charging.
2. It seems there is software on the phone to limit impacts of this heating (is this really Ford's issue?)
I find it funny - Apple's guidance is essentially -
If it gets hot - move it to somewhere cooler /aka 'common sense'
Easy-v
U S A
BadSquatch
From https://en.wikipedia.org/wiki/Qi_(standard)
Regulation of the output voltage is provided by a digital control loop where the power receiver communicates with the power transmitter and requests more or less power. Communication is unidirectional from the power receiver to the power transmitter via backscatter modulation. In backscatter modulation, the power-receiver coil is loaded, changing the current draw at the power transmitter. These current changes are monitored and demodulated into the information required for the two devices to work together​
(the phone regulates the power output of the charging pad / hence the guidance to keep the pad clean, ensure there is nothing between the phone and the pad, and that a case can interfere with charging, keep coins off the pad etc as recomended here https://www.ford.com/support/how-to...le/what-is-the-wireless-charging-pad-feature/)
Having said that - on long trips, yes my iPhone does get 'hot'.
I work around this with a 3 inch lightning cable and just plug the phone in and use the wireless charger as a convenience for shorter trips under an hour
MTinPA
Matt
Southeast PA
BMW 335i
After a 2 hour trip in my Bronco yesterday where I had my iphone on the wireless charging pad (no case), it seems to have fried the iPhone Qi hardware. It will no longer charge wirelessly on any of my charging pads or MagSafe. Apple ran a hardware diagnostic and confirmed there's an issue. I can't say for sure that the Bronco charging pad caused the problem, but it seems very likely. I would be careful using it.
