- John
- Mar 16, 2023
- 15
- 711
- 975
- New Jersey
- 2023 Ford Bronco
- Wildtrak
Some background. Recently changed my oil using Pennzoil Ultra Platinum synthetic in my 2023 WT. I often travel a 200-mile loop - straight run at 75ish MPH. With the previous oil, Motorcraft synthetic blend, the temp would range from 201-209 (give or take). With Pennzoil, i see an approx. 5 degree drop in oil temp - ranges from 196-201 degrees.
Now for the odd item. When the temp increases past 199 degrees, the gauge jumps to 201 (and 199 when decreasing in tempature). It never lands on 200 degrees. This has been consistent for a couple weeks now. My hypothesis is there is a programming bug. I can hit all other temps in that range accept 200. I’m using the multi-gauge temp screen (boost, oil temp, trans temp, and battery).
Anyone else see this behavior?
