pressure wash having a stroke - solved
Ixr
2022 2DR BASE SAS
Ford Bronco pressure wash having a stroke - solved IMG20230904095231
Ford Bronco pressure wash having a stroke - solved IMG20230715000252
Ford Bronco pressure wash having a stroke - solved IMG20230312114820
Ive got a cheap electric $90 ryobi pressure washer and dirt cheap foam cannon from amazon.
Works great.
Mkass
Amazon search cat pressure washer. You tube reviews are good. We like ours
Wark
Kurt
Syracuse, NY
'22 Ford Bronco
If you don’t have the minimally acceptable water pressure or if you are restricting the pressure through valves or hoses, it will not work. Street pressure should be minimum 55psi and max 80psi. Run the hose out without kinks and fully open the hosebibb.
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
With my electric PW, when everything is on (water and switch), and I’ve already bled all the air before cutting it on, mine will cycle on and off when not pulling the trigger, it’s a bad valve, it normally cuts off when it reaches pressure, but the valve is leaking pressure back into your hose, causing it to cycle on and off.
CaptFett
Drew
NoVa
Lx470
Are you using an extension cord or is it plugged directly to an outlet?
The sound is similar to when my pancake compressor for trim carpentry is not getting enough amperage.
aniljavali
aniljavali
Anil
Plainfield, IL
www.youtube.com
Bronco Badlands '22 & Tesla 3
direct to plug in the wall
aniljavali
aniljavali
Anil
Plainfield, IL
www.youtube.com
865Bronco
Robert
Knoxville
AMB Badsquatch, Land Rover LR3, Ford F-150
HCGxKaLiBeR
CT
2025 BMW X2 M35i
Does it run when you pull the trigger? I mean it sounds like it kept trying to build up the pressure in the system as the waters that are leaking out of the connector.
I have some generic electric pressure washer that I bought 4-5 years ago for ~$120 .
I use hot water (better cleaning) and RV water filter (reduce water spots) on it.
Both the washer and the filter say hot water not recommended, but I have zero issue with it.
OCNORB1974
Dale
Missouri
2022 Maverick
bought this pressure wash to keep me Bronco clean from Costco. but this feels like having a stroke. is this normal? which pressure wash do you use it on your car?
appreciate your feedback.
Sounds like a topic for pressurewasher2g.com?
buckhorn_cortez
New Mexico
F350, SHO, Bronco
Your pressure side hose fittings are leaking. The unit is losing pressure so it is short cycling to keep the pressure in the hose constant. Stop the leaks and the unit will stop short cycling.
Beachin 74
Delaware
I have some electric home/lawn care tools that work very well. An electric pressure washer isn't one of them.
That's just one of the things that I have found, a gas engine one does better.
NorthTexasBronco
Wichita Falls Texas
2023 Outerbanks 4 Door, 2023 Wildtrack 4 Door
I have that same one and that is definetly seized up, return it. Mine has been great for 2 years now. remembr to turn on water let it push out all the air then turn on the switch.
