Sure, if you want even less people to buy them.Holy crap! Should we raise our price?
We will attach a video soon, but it is fully plug and play, and uses a harness adapter that taps the DRL and blinkers inside of the headlights. There is a quick connect on the adapter so you can pick if you want the drl to be the RGB portion on the light, or the white strip light that acts as the DRL.I dig it.
How easy or not is install?
I’m still confused on what these will do once installed. Are the controlled by the drl and turn signals? So if the drls are off, these will be off? Can the lights be switched from white to rgb without opening the hood?We will attach a video soon, but it is fully plug and play, and uses a harness adapter that taps the DRL and blinkers inside of the headlights. There is a quick connect on the adapter so you can pick if you want the drl to be the RGB portion on the light, or the white strip light that acts as the DRL.
All said and done it will take about 30min to install this product from start to finish.
This right here! Make the LED across the top of the already existing trail sight or make a whole new one. Either way, keep the trail sight.They should make a trail sight light that isn't a delete too! Cool to have the turn signal and lights on the standard looking trail sight
I find it strange that ford did not do the same with the tail lights. Only the base has standard bulbs." 2021+ Ford Bronco with Factory Halogen Headlights (Base Tier) "
This is incorrect. All Broncos including the Base have factory LED headlights. I have one of the cheapest Broncos you can get, and honestly, I'm blown away how much stuff it has.
Doh. Wish I read this before I purchased! Well I hope they really sort out the issues before the product goes live. Appreciate your commentary here -Quake had these installed on a Bronco at SEMA. The lights were stuck on the blue setting. I asked to see how the turn signals looked, and the guy told me he couldn’t show me because there wasn’t power to the truck. Which was odd - given everyone in the show has power, and the lights were powered on, just stuck on the blue tint. (supposedly they are RGB, and do many colors with a key fob remote that he had with him, but it wasn’t working).
Seems as if these were already broken and not functioning properly. If you can’t get them working at the most important show of the year, perhaps there’s something wrong with the reliability of this product? I hope not, but you have to wonder.
hopefully you’ll have good luck with them. They did look like they fit well. I saw in another post. He wound up getting power to the truck because someone commented on it was a fire hazard with all the extension cords! I wish you luck! Be interested to see how they work for you. Cause they look kind of cool. Let us know in an update please.Doh. Wish I read this before I purchased! Well I hope they really sort out the issues before the product goes live. Appreciate your commentary here -
