Reveal Bronco - Different Rear Suspension Components
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I was just thumbing through old photos and realized that the reveal "Nintendo" Bronco has a different rear suspension setup.
Obviously this is a totally custom built non-functional model.. and the adjustable coilover makes sense to also fine-tune how the mannequin looks... but I thought this was interesting nonetheless.
(Also looks like the driveshaft isn't installed either.)
Ford Bronco Reveal Bronco - Different Rear Suspension Components Screen Shot 2021-03-15 at 16.38.34
https://www.caranddriver.com/photos/g33266105/2021-ford-bronco-4-door-revealed/?slide=30
Felix808
SRV CA
That's what she said. :ROFLMAO: :ROFLMAO: Never gets old
Actually it does get old.
On the bright side they did get rid of the rear swaybar ;)
evoaire
Evoaire
VA
maybe a bronco
Maybe true but they don’t make em like they used too
MyATV
ATL
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
That's not even your conventional "ride height adjustable" coilover. That's pre-load adjustable, which yes can accomplish the same thing. Or someone put it on upside down:LOL: Prototype/SEMA show off builds are never built half ass and wrong to get them rolled out the door. LOL
KJR50
K
SoCal
I'm not telling U.
“Upside down” orientation, different doesn’t equal automatically wrong. It’s an inverted shock design, handles alot more sideways forces, especially in high speed off-road application like rallying where they are subject to extreme rough track/race conditions.
Inrustwetrust_
Alex
Peoples Republic of Massachusetts
2021 Bronco 2dr
Aw yes the bluetooth driveshaft!
crowdpleazer
Daniel
West Virginia
Ford Ranger, Honda Civic
Felix808
SRV CA
That's not a 9" though...
Sure looks like it, just with an updated housing. What do you say it is?
Edit: The pinion section does look a little different. What axel is this?
crowdpleazer
Daniel
West Virginia
I can't identify it exactly. On a 9" the bottom 2 bolts that hold the center section in are partially covered by the pinion. Just enough that you can't use a ratchet and socket to get the bottom 2 nuts off, you must use a box end wrench.
I'm not a rear end expert, just know the 9 inches from racing with them.
Felix808
SRV CA
I've had a couple myself ;). I don't know of any other modern (1960+) Ford axle that has a drop out 3rd member, & there are numerous 9" housings & 3rd member styles.
jay-rod427
Jerod
KS
That is def a 9" ford center section. There is different versions over the years, but improvements were made for bolt access to use studs as well. That is a cast "stock" 1pc pinion support version. not a billet race unit. The aftermarket drop, bolt on pinion support and offset pinions are what get tricky on the mounting bolts.
Edit: now the more I look at it that may be a Toyota/Landcruiser style 3rd member! With the long tapered 1pc pinion nose.
