Rough Country 40inch LED Bar????
Big Lowery
Matthew
Parrish, Alabama
2023 Bronco 4dr
Maybe someone can help me. I have a Rough Country 40inch LED light bar I bought. I want it to run off of the aux 2 switch. The RC says it is 210watts is it safe to run it off of the Aux 2 switch which is a 15amp?
Ford Bronco Rough Country 40inch LED Bar???? IMG_7964
cr117
PNW
Bronco, EV6
210 watts / 12 volts = 17.5 amps
You’ll need to run it off of aux 1 (30A) or use a relay.
Big Lowery
Big Lowery
Matthew
Parrish, Alabama
2023 Bronco 4dr
if i use the relay could i use the other aux switches? Could i use aux 1 for a winch?
swooshdave
Portland, Oregon
Mustang
You mean just as an on/off for the winch? It can't power the full winch.
