Rough Country Black Series Ditch lights booboo.
Southern62
William
2023 Outer Banks 2.7 Lux
Lets say I was installing the above mentioned lights on my Bronco. Everything going well then I dropped the t-30 bolt to the inside... somewhere. I can't find it. Now I could just get another t30 torx bolt and install it but I like the Bronco one. Where can I get a replacement?
Southern62
Southern62
William
New question, M5? M6? size correct? If I buy plain janes
Benoack
Brandon
Allen, TX (DFW Area)
Ordered May '21 Badlands Sasquatch hard top, lux,
I second this question. I just did the EXACT same; dropped the T30 bolt into the fender well and cannot find it :|
Any thoughts on an equivalent or where to get replacement
Heckler
Larry
San Mateo
2023 Bronco
I did that installing my hood struts, dropped the bolt down into the fenders area, I used a magnet on a string to retrieve it, magnet doesn’t stick to the aluminum so it came out pretty easily.
Benoack
Brandon
I used a magnet as well. I heard it drop and get into the fender area. I even removed the inner liner of the front fender well to find. So frustrating as I was done with the install and was just trying to reposition (hide) the cables of the ditch lights.
Home Depot and Lowes were useless; I have not tried NAPA yet. But first want to see if/where others have obtained replacements
Heckler
Larry
San Mateo
2023 Bronco
Yea Lowe’s and Home Depot suck when it comes to hardware, especially for anything metric, I have better luck at little ACE Hardware stores.
subg
Illinois
2023 Base Bronco 2 Door
I did the same. Took out the inner fenderwell and found it.
GL
Squatch
Miami
I use boltdepot dot com for everything I want, especially, stainless steel.
Also, I felt very misled about where this thread was going:
Ford Bronco Rough Country Black Series Ditch lights booboo. 1000009347
Msell71
Ames, IA
2023 Bronco, 84 SVO, 66 2+2
McMaster-Carr has the TORX and TORX+.
