My cluster is showing 45-47 PSI for all tires. I’ve seen as low as 43-44 depending on the temp. Owned for 6 months with 2k miles. Have not touched the tires so likely came this way from dealer if not slightly higher.
This is clearly overinflated but not sure is it makes a difference. Anyone else in this boat? Should I bother leaking out some air or will it have little to no effect on ride quality/mpg? I’ve always run tires a couple PSI higher so prevent any future forgetfulness. But not sure if the dealer overinflated too much to the point I should take action and lower it
