Shift Knob and Boot ideas
Hkak45
K
Illinois
21 Bronco Black Diamond
Great write up, it was perfect. I went with the Faux Alcantara from Redline.
That looks great! How bad was the install? I ordered mine with standard stitching but seeing yours makes me wish I went with that stitch pattern
JJ_Gecko80
Juan
Ohio
2022 Ford Bronco Big Bend
Just make sure to follow skithebadlands' write up and it will be fine. Let's see pics when you're done.
Lèòn
Jersey
Ford Bronco Shift Knob and Boot ideas 31922C3E-374D-409F-AF07-4A4DC9FC9811
Oracle Fiber Optic Kit, spv headlight tap for backlights, Armrest cover
Ford Bronco Shift Knob and Boot ideas 1C33F3BD-189F-453C-9CAC-3CD522851835
Need a grip tool or something to remove the Boomba knob to install the shift boot, any recommendations?
Herbie
Alex
Cleveland OH
2022 Badlands
Installed my Redline boot today with the Badlands orange accent stitching.
Ford Bronco Shift Knob and Boot ideas 20230304_153310
Herbie
Alex
Cleveland OH
2022 Badlands
coreymd
Corey
DFW, TX
'22 Bronco, '22 BMW 330i
Had to use this to remove the bolt holding the knob to the shifter assembly:
Powerbuilt 240094 8 Piece Zeon Metric Hex Bit Socket Set - with use for Damaged Fasteners, Standard, Rusted, Rounded Bolts, Size from 3mm to 10mm https://a.co/d/09Esa6U
Once everything was apart, the challenge was in refitting the components around the thick leather. I wound up cracking the lockout collar at the bottom, probably because I had too much of the leather wedged between the pieces. Didn't notice until it was all reinstalled in the Bronco.
Looks great if you don't inspect it too closely.
Ford Bronco Shift Knob and Boot ideas PXL_20230305_213018337
Hkak45
K
Illinois
Ford Bronco Shift Knob and Boot ideas PXL_20230402_155845999
Ford Bronco Shift Knob and Boot ideas PXL_20230402_155854710
Installed my Redline custom shift boot today. It was a very tight fit but looks good. Only complaint is the tight fit made the stitching spread a little bit and the plastic shift collar cracked from the thickness of the leather. Also have a twistedshifterz custom white shift knob. Overall I am happy with it for the price.
Ltjb8
Jill
Pittsfield Twp, OH
www.instagram.com
‘22 Bronco Wildtrak
That looks great! Perfect color combo. What color blue thread did you go with from their list...or did you have to order the special color matched option? I couldn't decide on the blue so I haven't ordered one yet.
Hkak45
K
Illinois
That blue is their "grabber blue". It was the closest one they had to the stock stitching on Black Diamond.
Maine Explorer
Ben
Maine
22 bronco
I know it's silly but I really want a black rubber accordion one. Might have to take measurements and start scheming
Bikeric
Tulsa
2022 Badlands LUX on 37's
I tried to copy the Ford Bronco concept rig for my Badlands. Did the Redline leather boot, but kinda wished I had gone with a smoother vinyl. Oh well, I'm still happy with it.
Ford Bronco Shift Knob and Boot ideas brYahWX
karguy08
VA
GT350
Where is this shift knob from? I've been wanting a new shift knob in cactus gray, but i can't find anywhere that will color match or offer the ford factory colors.
Lifeliberty
Moonbeam👀
Columbus, OH
Did you replace the lock out? I recommend the metal ones.
coreymd
Corey
DFW, TX
I haven't, but I have seen the posts about them. I might change it if I ever do any other upgrades, like the short throw or shift knob.
I assume you replaced yours - do you have any detailed feedback on it?
