Soft top fraying
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I wouldn't call that a fray, it's definitely a snag of some sort. Whether or not op caused it, I dunno, it could have happened at the factory. Check your shit extremely thoroughly at delivery, people!
guerro
AZ
2023 Bronco Raptor
I don't think so, only road driving so far. Definitely a possibility though. Tops been rolled back unless it rains.
May want to investigate where the top lays when rolled back and the range of movement when driving. It may be bouncing down and hitting something?
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Wanted to share something I noticed yesterday too see if others are seeing it and if there are any causes or solutions. The front driver side of the soft top has a small fray starting. It started 5 days after getting the bronco. The fray is at the terminal end of the support frame. The support frame does not feel or appear sharp. Thoughts?
2021 bronco base 4dr
Is your roll cage paint rubbing off like others have noticed?
Bronc-itis
E
South Florida
Q50 (bronco soon)
I’d hit that with a lighter first to melt down that material sticking out. That should keep it from getting worse. A dab of gorilla glue on top of that should protect it. It is still be pissed off.
buzpro
Binky
Tacoma
Christ I’m thinking about staying away for awhile everyone I hop on hear there’s a new bronco issue wtf
its a FIRST year model .... Of course there's gonna be issues
Bronco21fan
Angelo
NewJersey
All the time they had to get this thing correct me and many others are tired of the well it’s a first year vehicle excuses
buzpro
Binky
Tacoma
Its not an excuse .... all the planning in the world will still bring about unforeseen issues on such a complex machine .... nvm the QC that's involved with vendors on a 1st year model
R11
Rob
Sparta, Tennessee
www.basequatch.com
Bronco Base Sasquatch 2.7
Ford Bronco Soft top fraying nl0iv4xubdzpg9jn8fjq9e9fenm1xq7vssvfot8v&rid=giphy
Banshee
Augusta GA
It is on the driver side where the top gets operated from. It seems to be from taking the soft top from 'rolled back' to fully down, and vice versa. Could be avoided by lowering the top cautiously or with two people. I saw another post saying to lay felt tape on the area.
The fray could be from a 'snag' but didn't take her off road until today. The place that it is occurring makes me think it is a fray from the inside out due to the frame. I did get a contact for Ford and I will be sending in more pictures and description so that they are aware and can track the issue. Maybe they'll see a trend, maybe it is just a snag.
Addressing the comments on issues: this is a trail crushing, smooth highway driving, rugged machine with fabric for a roof. The high amount of engineering that went into the design are apparent throughout the vehicle. However, just like a Jeep, these types of rugged, multi purpose vehicles will always have issues, no matter the model year. Owners of Broncos should moderate their expectations more in line with that reality... I didn't buy a Lincoln. This thing is an absolute savage off-road!
Ford Bronco Soft top fraying 20210729_154751
Ricky_gibbs
Ricky
Brentwood, CA 94513
Mini countryman
It almost looks like a cat got to it. I could be wrong. If that's the case then it's going to happen again
EMoo22
Erin
Buttercream119
Ford Explorer
My immediate concern was that the support frame was rubbing through the fabric. Doesn't appear to be the case but hard to tell. I'll keep my eye on it and update. Wanted to inform other soft toppers and develop a quick solution for people to use. Getting a bottle of gorilla glue tonight.
Dave-O
College Station, Tx
F-150/Mach-E
Good thing you didn’t buy a Lincoln. Those things have the worst reliability ratings 🤣
RWBigBend21
Ric
Tampa, Florida
Ridgeline RTL
There's another thread somewhere (Ha- No Pun intended) Seriously, a discussion thread where someone else has this same problem I have now with my Soft Top, fabric is failing. I thinking this is the spot where it folds back to the first open position
Ford Bronco Soft top fraying Soft top fray
EKOBX
Erik
SMF
The top corner? Looks normal to me.
When opening/closing the top look at anything that could be hitting that section at an point of the movement.
I have a similar fraying spot about halfway down the-passenger’s side of the top.
Ford Bronco Soft top fraying 1652300567958
Ford Bronco Soft top fraying 1652300591869
After some thinking about what I may have hit to gray the top, I took it through the process of putting the top down. When I had it flipped back I noticed something different between how/where the top folded on the passenger’s side versus the drivers side:
Passenger:
Ford Bronco Soft top fraying 1652300716072
Driver:
Ford Bronco Soft top fraying 1652300759519
On the r passenger side the top is rubbing on the plastic piece that warns you not to pitch your finger and has, clearly started tearing the top. It looks like you might be able to remove the plastic piece, but I want to leave it as is until I talk with Ford and show them the issue.
Ford Bronco Soft top fraying 1652300882299
I’m guessing your top might be rubbing some other random part of the rig and creating a similar issue.
