- Kix
- Jan 9, 2023
- 4
- 38
- 112
- Dublin, CA
- 2021 2dr 2.3 MT
- Base
[EDIT - for new details & context see latest posts/replies]
Hey all,
Long story short (and lessons yet to be learned) - Upgraded my Base 2dr suspension with Eibach 2.0 and 35 Methods+Mickey Thompsons, and now my *Upper control arm bushings are toast after about 3000 hwy miles.*
What is wrong to my (mis)understanding:
- Upper Control arm bolts on both sides have about 1/4 gap between bolt/nut and rubber bushing. This allows the arms to play back and forth causing shift in a dramatic, loud, and very disturbing the frame manner. Doing a right turn at a traffic light hints to pedestrians about the quality of your vehicle, while getting in and out of a parking spot wakes up the dead and makes you want to join them.
- Although Eibach 2.0 coilovers are (according to their crafty manufacturer) supposed to work with the stock suspension and upper control arms, I am starting to doubt that somewhat.
I did 2 things wrong:
- Coilvers changed the geometry of the suspension. 10 bonus points and a Rice Krispy.
- Rims with 0 offset and a much wider tire also changes the geometry especially when maneeueueuvering (bonus points for spelling) lock to lock at low speeds. You can see the upper control arm bending in pain, forcing itself out of alignment while the wheels are being turned lock to lock. 20 bonus points and a pint of beer
The Solutions (kinda)
- Tighten the upper control arm bolts back to spec. Yeah, well.. they aint moving. These puppers are stuck stuck. I should be tightening them while vehicle is on the ground resting on the wheel and tire, right? I will try to tighten them with the load of the vehicle off - wrong but it might work.
- Buy new upper control arms, and/or get poly bushings. Most likely what I'll do, but my fear is that I am opening a itty bitty pandora's box. The wrong geometry forces will remain, so if I stiffen the upper control arm, where would the magical twisty energy go? Sway bar links?!
I need your help, Bronco fam. Let me know if any of you have experienced this or simiar issue. Tell me what I did wrong, and how I can correct it.
Here is a video (REUPLOAD) Its muted due to youtube copyrights
Hey all,
