I’ve got factory front BRAptor upper arms if you need them
Yes I regeared to 5.38 when I still had 37s...but quickly switched to 40s afterwards.Would you have regeared to 5.38s on the back end rather than going to a Dana 60 if you were running 38s?
I wheel on narrow east coast trails and chose to beef up the axles rather than going portals because I didn't want to go wider. I'm curious what drove your decision to not go the portal path and also go with the wider 73".
Are you able to use stock Braptor axles or getting something custom made?Yes I regeared to 5.38 when I still had 37s...but quickly switched to 40s afterwards.
I decided I want more wheel travel over ground clearance...all of the long travel setups need a wider front A-arm(s) including the Braptor, So when I needed to order a new rear axle, I decided to order the wider version to match a wider front. Got the Braptor UCAs, longer axles, new CV boots, and ICON tie rod spacer lined up now and still waiting on Braptor LCAs...
my overall width or track width will be less than a Braptor because the knuckles are different.
I don't want to use stock Braptor CV axles...they have less spline and are smaller than my spicer upgrades, and they have the ultra stupid vacuum activated hub disconnects...built onto the CV axle...NO THANKS.Are you able to use stock Braptor axles or getting something custom made?
Can you please explain what this part does and when it is beneficial?It’s Rockkrawlers new bronco 4-link.
https://rockkrawler.com/bronco-pro-x-triangulated-4-link-conversion/
Triangulated 4-link will allow you to loose the track bar….Can you please explain what this part does and when it is beneficial?
Thanks. Why do I want to loose the adjustable track bar that I just installed as part of my lift kit?Triangulated 4-link will allow you to loose the track bar….
Due to circular motion of the track bar. It's good enough, but the 4 link triangulated suspension only allows the axel to go up and down perfectly. Less of that rear sway.Thanks. Why do I want to loose the adjustable track bar that I just installed as part of my lift kit?
razorback pretty much covered it. As the suspension cycles the track bar tends to pull the axle side to side….especially if it is already at an angle from a lift.Thanks. Why do I want to loose the adjustable track bar that I just installed as part of my lift kit?
Check out Exodus 4X4, they did a youtube video on it.Is RK the only option for a 4 link right now? Has anyone from the forum installed one yet?
Thanks, you took me from what is it to how have I lived without this in one simple videoCheck out Exodus 4X4, they did a youtube video on it.
True, with only 1.5 " lift It's hardly noticeable. I've owned some factory 3 links that I modded a bit...and the ride, handling and articulation was FANTASTIC. I'll go this route eventually.If track bar is level then there is very little lateral motion due to the length of bar and small angular motion.
