Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics
Sandjob
MI
2022 Base Bronco with Sasquatch
I wanted to show a few pics of my recent mudflap mod. It was pretty easy. I templated the fender flare with a pencil and paper, held up the flap to the oem hole locations, marked an endpoint at the fender and an endpoint at the bottom. I then put my hand drawn template on the beginning and ending point and traced a line to cut. Forget dremels and just use a good pair of snips or heavy scissors. Use a dremel to smooth out the line if needed. I took the cut off parts and used two small screws to create an L bracket (a mod from a previous poster). 2 of the u brackets were used to fasten to the fender. I used the factory fastener locations and added an additional push pin and a leftover c clip to attach to the fabric liner.
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220320_180840
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220320_180846
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220320_180853
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220320_180907
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220320_180910
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220318_180154
Ford Bronco Standard mudflaps modified and installed on SAS Sasquatch Base Bronco - pics 20220318_180151
Mr. Nice
Jayson
Minnesota
12' Boss302, 08' Audi TT, 13' CRV, 14" Ridgeline
Looks pretty good to me. I am waiting for flaps that don't ride so low. By the time I get my July 2020 reservation Bronco someone will offer them. Maybe in 2023 or 2024.
Sandjob
Sandjob
MI
Good Luck on getting your Bronco in. I ended up buying a base that was abandoned in lieu of my wildtrak.
Broja24
Bret
Howdy1283!
2022 Bronco Wild Trak
What standard flaps are those?
Sandjob
Sandjob
MI
They are standard non sasquatch mud flaps. They are not supposed to fit the sasquatch, this is a mod to make them fit. The alternative is the gatorback for a few hundred dollars more.
Melvin
Nice write up, was able to put them on mine.
Melvin
Have you put the rear oem mudflaps on?
Sandjob
Sandjob
MI
No, I haven't done the rear as I was only worried about the paint on the doors. I would expect it to be easier on the rear. It looks good to me with just the front. Did you do the rear?
Melvin
No, I have the oem rears. Debating on whether I want to do them or not. Looks as though they would be easier to put on, but wanted to see a pic first. I put the fronts on for the same reason.
