Sub Amp looses power - Apple car play announcements ... Map text etc.
Tombky
Thomas
2Conline!
2022 Bronco
Any thoughts.. I added a sub and amp to base 6 speakers system.. I am loosing remote power to the sub amp whenever i get a text or announcement via carplay... Usually goes away by swithing back to radio.
Any thoughts..??
Tombky
Thomas
2Conline!
2022 Bronco
Dealer installed they used speaker level inputs from the front channels
Deleted member 32220
Guest
No expert here…but since the chimes, blinkers, CarPlay messages are all generated by the speakers. The pause in the CarPlay messages probably is just a bit too long to keep the line converter triggering the remote turn on energized. Kicker key amps seem to be working very well. PAC may make a plug n play remote turn on that doesn’t use an auto turn on from low level inputs. Someone more knowledgeable than me in this department will likely have some better answers for you.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Exactly what I was thinking, if the answer was speaker level inputs! Might be worth changing to a source that's switched with the ignition
RAKET
Derick
www.raketdesigns.com
Any thoughts..??
My 2 cents, I tapped my auxiliary (blue wire) to a fuse instead of counting on a signal through my speakers. I was always iffy about not having desire to connections. Hope that helps.
Tombky
Thomas
2Conline!
2022 Bronco
Thanks for the update.... going to rewire and tap fuse...
RAKET
Derick
Try it and see. Someone posted a diagram in the past and they tapped into #2 fuse under the dash (panel). It’s for the automatic windows, which shuts off when the engine/accessory is turned off. Hope that helps and good luck.
DJ1
Minnesota
2022 Honda Civic Si, 2020 Toyota Tundra TRD Pro
Ford Bronco Sub Amp looses power - Apple car play announcements ... Map text etc. remote wire
