"The Bus" Build
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
Orange, hence "the bus".
This isn't exactly a "jaw-dropping"-caliber build thread, but more of a documentation of accessories that I add on to my 4D Badsquatch, requiring merely a basic level of mechanical aptitude and some everyday tools.
So far I've added some Rigid 4" ditch lights, a Ford Performance drawer system, and just this morning installed the ARB twin compressor with a KR bracket (see photos below).
Additional planned accessories include a Warn winch on an RC winch plate (Mod bumper), Baja Designs fog lights, a low-profile rear bumper with improved depart. angle, ham radio antenna system, and finally a soft-top roof rack system when those become available. I'll add photos as I install these items. For now, some pics:
Ford Bronco "The Bus" Build PXL_20220731_215920918
Ford Bronco "The Bus" Build PXL_20220731_215849113
Ford Bronco "The Bus" Build PXL_20220731_215802367
Ground_zero298
Scs michigan
Very nice!
WheelMe
WheelMe
Patrick
Northern California
I've been adding a few items here and there, and will post pics ASAP. Some of these items include:
4x4 TruckLED's Baja Designs foglight kit
Trailgater tailgate drop-down table
Rokblokz front mudflaps
Bilstein 6100 shocks for a 2" lift (yet to be installed)
Rough Country HD Mod bumper mount + Warn EVO 10S winch (yet to be installed)
ASFIR Cross member skid covers (these were made known to me by a fellow forum member - I'll update with his handle shortly)
The mod that I'm most excited about are the ASFIR cross-member skid covers, as my cross members get bashed each time I go wheeling (here's a link if folks have no idea what I'm talking about: https://www.asfir.com/skid-plate-599662.html). Made in ISRAEL - to boot!
More soon.
Ford Bronco "The Bus" Build 1663873374467
Ford Bronco "The Bus" Build 1663873586438
WheelMe
WheelMe
Patrick
Northern California
More stuff ordered and coming (There's nothing more fun than spending money):
IAG rock slider steps
Soft top hydraulic lifts
Rocker protection film
I'm in the middle of installing a Warn EVO 10S onto THE BUS' MOD bumper, using the RC mount. I must say that the mount's isn't pretty - the welds are ugly and the pieces are rough looking; some bolts are missing as well. Overall, though, it's a good design, and not hard to put together - excellent installation instructions, by the way.
Despite a good design, they can't possibly accommodate all the winches that are out there - one example being my Warn EVO. The body of the EVO juts out so much that the RC-included proximity sensor locking plate won't fit, despite any amount of grinding - I'll have to come up with my own solution to keep the sensors from falling out of the mount holes... not a big deal.
Some initial photos below - I'll post more when the job is completed.
THE BUS with a big smile, awaiting his new winch.
Ford Bronco "The Bus" Build PXL_20220924_191344942
The mess of wires go to the Baja Designs fog/spot lights clusters in the bumper.
Ford Bronco "The Bus" Build PXL_20220924_185740689
This piece is attached to the inside of the bumper by four bolts; the entire bumper is then attached (through the two holes seen here (plus one on the other side of the tow point) to the Bronco's chassis, seen in the previous photo. This is a beefy piece.
Ford Bronco "The Bus" Build PXL_20220924_185859470
The winch is now bolted to the mount. I've removed the control box from the top of the winch; it'll be relocated to the engine compartment (probably using a BAMP bracket) so as not to block the BRONCO lettering on the grille. In terms of the camera, I'll be installing a JCR camera relocation kit in order to retain that capability, which I've found very useful while cresting a hill, or threading through boulders that I can't see from the driver's seat.
Ford Bronco "The Bus" Build PXL_20220924_232030175
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
It’s WAY easier if you mount the bottom half to the bronco first. Then attach the top plate, winch etc. I learned this on my second install.
WheelMe
WheelMe
Patrick
Northern California
Lol, I wish that I'd thought of that, which would've saved the entire family some muscle - it took all three of us to hoist the monstrosity up to the bumper and bolt it on). In any case, the "Bus" now sports an awesome winch, though it's not electrically hooked up yet - I need to order some extension cables for the control box.
At first, the proximity sensors errored out, but with a bit of wire-jiggling, they started working properly - hope it stays that way. I also noticed that the steering feels heavier while maneuvering in a parking lot - the extra 80 lbs. is taking its toll. I forgot to measure how high the front sat before the winch install - it might have lost 0.5"; luckily, I have some Bilstein 6100 shocks coming, which should bring the height back up.
It looks pretty good, in my opinion. "Hey Jeep Guy, need me to winch you out?!" :p:p
Ford Bronco "The Bus" Build PXL_20220925_203153463
Ford Bronco "The Bus" Build PXL_20220925_201124015
Ford Bronco "The Bus" Build PXL_20220925_201151388
Ford Bronco "The Bus" Build PXL_20220925_201051130
Ford Bronco "The Bus" Build PXL_20220925_201031285
BroncoSarge
Jeffrey
Gotta run those cables in back. You can tuck them between the bumper and the body color piece. i also removed our decals and blacked out the chrome.
Ford Bronco "The Bus" Build CF0C239C-1C13-4AE7-AC28-61C9B59188BD
WheelMe
WheelMe
Patrick
Northern California
That's the plan - the black negative cable is tucked around the winch temporarily till my extended cables arrive. One thing I haven't done yet is trim the bumper covers - what tool did you use to trim yours? I'm thinking of using my dremel with a cutting wheel.
WheelMe
WheelMe
Patrick
Northern California
Fun times ahead (just Forscanned):
Ford Bronco "The Bus" Build SportMode
WheelMe
WheelMe
Patrick
Northern California
The Israeli cross-beam armor has arrived - stainless steel, very well-made. I'll get these installed after I grind off the rust on the cross-beams and repaint them.
Blue skies today.
Ford Bronco "The Bus" Build PXL_20221004_211105515
WheelMe
WheelMe
Patrick
Northern California
Slowly but surely... relocating the winch control box and installing the JCR camera bracket.
Warn was out of stock on the EVO 78" extended cables, but the Zeon counterpart worked just fine. Routing the cables from the engine bay to the winch, one by one, was a relatively simple task.
The grille was surprisingly easy to take off, and re-install - love how modular the whole truck is.
The Bilstein 6100s get installed tomorrow - can't wait to see the new stance, and test out the new ride height on some rocks in a couple of weeks.
Ford Bronco "The Bus" Build PXL_20221009_214041305
WheelMe
WheelMe
Patrick
Northern California
The winch now works, and I replaced the Warn fairlead with one from Yankum Ropes - I'm ridding the winching system of metallic objects that can kill... the Warn hook is still on, but will soon be replaced with a spliced loop that hangs on either side of the new fairlead.
Ford Bronco "The Bus" Build PXL_20221019_002816581
Ford Bronco "The Bus" Build PXL_20221019_002825460
On another note, the ASFIR crossbeam armor has been installed - looks great and should do the job well; we'll confirm after the hitting the Deer Valley trail in CA in a couple of weeks.
Ford Bronco "The Bus" Build PXL_20221016_181932726
Ford Bronco "The Bus" Build PXL_20221016_181943899
Last but not least, I got my LIFT! Thanks to the new Bilstein 6100s, set at maximum height, I measure a 1.5" height increase at the CV joint... I was hoping for 2.0", but the winch system weighs 80 lbs., and brought the height back down some - the new shocks still "leveled" the rig, though, which is great. The 6100s are a noticeable improvement over the OEM SAS shocks - they're more compliant over irregular surfaces, and should much better in ruts that I'll be hitting this weekend on the trail.
Although there's now room for 37s, I won't go there in order to keep the rig's weight down and avoid added stress to suspension/steering components.
Have a nice weekend, and go wheel your Bronco!
Ford Bronco "The Bus" Build PXL_20221013_172932489
WonkyBronky
San Marino
'22 Wildtrak, '20 Raptor, Porsches, track cars
Looking good. Made me check out the ASFIR products, and ended up ordering almost all of their underbody protection!
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
I like that fairlead.
WheelMe
WheelMe
Patrick
Northern California
That's awesome! I'm glad that you find ASFIR's products up to your standards. Don't hesitate to contact them during the ordering/shipping process - they're very responsive.
