Three-piece top question
Erock
US
2018 F150 Alpine edition
I was thinking of this but then it removed one of the major selling points to me over the Jeep, no bars over my head.
I understand, I was thinking clamp on so it can be removed for the “open air” feel... but for those times like the OP was looking for that they wanted the front panels only. Say a smaller 1” square tube that can be stored in the back, maybe even folding or telescoping to save space.
Brad Fx
U.S.A
Jeep Commander
I’m pretty sure the answer is “no,” but is it possible to use only the two front panels of the 2-door hard top, without the back section?
I keep seeing No, 4dr as well, but then you Broncos riding around like this:
Ford Bronco Three-piece top question B06D77A7-B353-46DE-A2A2-EFB5550949A5
Ford Bronco Three-piece top question 4B4A5232-960A-428D-A28B-3B77091CE9B6
Erock
US
Fords stance seemed to be for “highway driving”, I’m certain it would be fine just crawling around where wind speed wouldn’t be a factor.
Adumb
Adam
St. Louis
'21 Area 51 4dr
Yeah I think I remember reading that you're good as as you stay under 40. Offroad. Mall crawling. Beer run. I think it's all good.
sanford
Ross
Columbus
Chevy Silverado, Subaru Crosstrek, Bronco
The problem is that the mid-panel has only two hard connection points (one on each side) near the front of the panel, correct? When the rear section is removed there are three points that aren't locked down to anything. We need to figure out a way to clamp the back of the mid-panel to the roll bar?
Ford Bronco Three-piece top question 1616594992498
amccue90
Andrew
Illinois
2021 Badlands
exactly, if you come up with something before I do, I'll just buy from you haha
Brad Fx
U.S.A
Jeep Commander
Yeah, some sort of clamp or locking mechanism behind the 2nd panel. Seems like it would be easy enough for aftermarket...
MississippiMule
MississippiMule
Oxford, MS
2015 Toyota 4Runner, 1976 Ford Bronco
Thank you for the insight. I used to have a Wrangler with a soft top as a daily driver. Pulled the carpet and lined the floors. If it was going to rain, I put the door windows on and top up. But never had a bikini top. Mississippi sun/heat with no cover up front in summer is brutal when you don’t want to show up at work soaked in sweat, but would be nice to not have the whole top on.
amccue90
Andrew
Illinois
2021 Badlands
amccue90
Andrew
Illinois
2021 Badlands
