Tire Pressures
hammonton NJ
broncos
What’s up everyone! I keep seeing people air down to 8 PSI for basic gravel trails, while others refuse to go below 25 PSI out of fear of popping a bead.
Let’s talk off-road tire pressures—what’s your sweet spot, and why?
Here’s my take as someone who spends way too much time on the trails: 12 to 15 PSI is the ultimate sweet spot for non-beadlock setups.
Here is how I look at the spectrum:
  • 20–25 PSI (The "Scared of Airing Down" Zone): Good for high-speed dirt roads or fire trails, but you’re sacrificing a ton of traction and getting shaken to death over washboards.
  • 12–15 PSI (The Goldilocks Zone): This is where the magic happens. You get a massive contact patch for rocks and mud, a noticeably smoother ride, and you're still completely safe from burping a bead on standard wheels.
  • Under 10 PSI (Beadlock Territory): Unless you're running true beadlocks or crawling extreme vertical granite, dropping this low on standard wheels is just begging for a flat sidewall or a derailed bead mid-trail.
Airing down isn't just about grip—it saves your suspension, saves your spine, and keeps the trail intact.
Where do you usually drop your PSI when you hit the dirt? Do you air down for light trails, or only when things get technical? Drop your rig setup and pressures below! 👇
Headsong
So many threads. Even a recent one. Search.
