Tow Hitch Install
  • Thread starter Deleted member 49144
  • Start date
  • Watchers 4
AK SNO RIDER
Ty
Alaska
I've had that damn wiring harness sitting in a box for a year now. Just can't motivate myself to do that bitch and a half of an install.
swmetal
C8 vette
My question is, what else do I have to add to be able to install this Ford 4/7 on the Ford hitch. What additional wires will I need? I already have the Curt 4 pin on the way, and I’ve already run the 12V line to the battery.
The 7 pin connector requires installing a brake controller on your Bronco. The 7 pin allows using a trailer with electric brakes. Most states require trailer brakes when towing above 3,000 lbs.
However, boat trailers with brakes don't usually have electric ones. Instead they have hydraulic surge brakes. Most boat trailers will require a 5 pin connector, which is like the 4 pin plus a 5th wire to your backup lights.
Guest
Ive run across a wireless brake controller that Curt makes, and I also came across autow brake and they look like good options. Will this negate the need to run wires? If I can run someone like this, then what other wires am I missing? Would I just need to splice in a 7 pin end onto the Curt 4 pin harness, so that I can plug it into the Ford 4/7 mount?
https://getautowbrake.com/
Guest
Or I can keep the Ford 4 pin end and bracket. Then just plug this right into it to be able to connect a 7 pin trailer
For some reason I don’t feel it would be that easy. Even if I was using the Curt wireless brake controller. Would I still be missing another wire from the battery ?
Ford Bronco Tow Hitch Install IMG_6831
swmetal
C8 vette
That adapter is for connecting a 4 pin trailer to a 7 pin tow vehicle, opposite what you have. If your trailer has a 7 pin connector, it has electric brakes. In that case you must have a brake controller, wired or wireless, for your tow vehicle.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
I also heard the harness wiring is no fun to install. What do you plan on towing? I just installed a Curt #13493 hitch which was easy but does not have a plate or area to mount an electrical connector. I only plan to hook up cargo brackets, bike racks, and maybe a very basic trailer with no lights.
Here is the Curt mounting plate for those not wanting the plug to hang out. For $1 it's an easy choice.
CURT 58300 Vehicle-Side Trailer... https://www.amazon.com/dp/B0049CGJAU?ref=ppx_pop_mob_ap_share
Ogre
James
Guest
Update 3:
Sorry I’ve been on hiatus for a while, went down to Key West for a bit to get away. Anyways, I decided to ditch the 7 pin idea and stick with the 4. I changed the box placement and I am going to put it behind the left tail light for a cleaner look. I’m going to use 3m double sided tape to adhere it inside the rear fender panel. I was able to splice together the Ford end onto the Curt wiring harness, that I finally received in the mail.
I’m using platform mounts to attach to wire ties, there is a good shot of what they look like in the pictures. These are great for keeping a cleaner look and keeping things in place. Tonight I’ll be running the wires through plastic tubing and getting it ready to install on the vehicle. After I get it all installed and plugged in, it should be ready to go.
In the meantime, does anyone have a good receiver they recommend (preferably and adjustable one).
Ford Bronco Tow Hitch Install IMG_6838
Ford Bronco Tow Hitch Install IMG_6941
Ford Bronco Tow Hitch Install IMG_6940
Ford Bronco Tow Hitch Install IMG_6942
Ford Bronco Tow Hitch Install IMG_6949
Ford Bronco Tow Hitch Install IMG_6950
Guest
Update 4:
After messing with this thing some more last night, I decided to again move the box down underneath the tail light. There is a perfect spot down there that is flat and it will fit right down in there without removing anything additional. I also spent some time shortening the harness that I goes to the left tail light, as Curt made this very long, at least for the area I want to put it in.
In the end I’m going to have a near completely modified harness, which I’m okay with, because it will have tubing and tape around it to where you’ll never be able to see any splicing. Adding some more pictures of where I’ve got now. I’m working on left side now, just need to figure out how long I need the ground wire. Last picture shows where I’m at with the harness so far, I shortened it just enough to go up the side of the tail light and plug in
Ford Bronco Tow Hitch Install IMG_6956
Ford Bronco Tow Hitch Install IMG_6958
Ford Bronco Tow Hitch Install IMG_6962
Ford Bronco Tow Hitch Install IMG_6963
Ford Bronco Tow Hitch Install IMG_6964
Guest
Update 5 :
Got the wiring harness to the correct lengths (most of it) and decided to mount it on bronco. I ran into an issue, was easily fixed but it to be noted. I don’t know if it would be the same if you don’t use plastic tubing, but I had to route the left tail light wiring behind the trim piece and the tail light itself. It sticks out too far if you don’t, and won’t let you mount the outside cover piece back on.
I took out the 3 plastic mount bolts that hold the small trim piece on, which I’ve circled in one of the pictures. Pop out the very bottom trim piece that wraps around the corner, only pop out the side by the tail gate. The other side is behind the fender guard. This will give you access to the bottom bolt. If you remove all 3 of these, it will give you just enough room to squeeze it behind the mounting tabs.
Tomorrow I’m going to run to the other side and see how much I need to adjust for length. I cut the power wire shorter because it was way too long and I’ll also connect that and screw the ground wire in. I think the time consuming part is behind, and it’s just more adjusting the lengths. I’ve just been working on it a bit every night after work, but should have it done by this weekend. šŸ‘
The last picture shows where I’ll be doing the final routing. Try to mount everything you can behind the trim piece, it will keep it out of the way when you go to mount the outside cover back on.
Ford Bronco Tow Hitch Install IMG_6969
Ford Bronco Tow Hitch Install IMG_6970
Ford Bronco Tow Hitch Install IMG_6971
Ford Bronco Tow Hitch Install IMG_6980
Ford Bronco Tow Hitch Install IMG_6979
Ford Bronco Tow Hitch Install IMG_6982
Ford Bronco Tow Hitch Install IMG_6981
Ford Bronco Tow Hitch Install IMG_6984
Guest
Update 6:
I got the left side all buttoned and finished up. With the cover on, you can only see the biggest section of wire, which won’t completely fit behind the panel. Once you get the panel on, you can put them over behind the bottom piece, and it should hide 95% of the wiring. I think the part that tweaked me the most was sanding down the paint off the frame lol.
After it’s all said and done, I’ll pretty much have a custom length harness, I hated all the extra that was hanging everywhere, and quite frankly, I didn’t have the extra room to shove it all back behind the tail light. I also shortened the end that goes to the hitch so where you can’t see it. I need to look for bigger frame pins that have the built in wire tie. The ones that Ford provided are too small at this end of the vehicle. Tonight I’m going to finish up with the right side, which is A LOT easier. Then I’m going to hope everything works.
I ran into an issue that I wasn’t sure about. It seems that the Curt kit and the Ford kit came with two different sized fuses. The Curt kit comes with a 10 amp, while the Ford comes with a 15 amp. I checked the power wire from both, thinking that could have been the difference, and they both use 12 gauge wire. I then contributed it to the frequency of the box. The Curt came with a 10 amp, and that’s the box I’m using, so that’s also the fuse I decided to use. Hoping I don’t have any issues down the road. I did make quite a few splices in different areas, but they are all tight, and with heat shrink wrap on each one.
Ford Bronco Tow Hitch Install IMG_6990
Ford Bronco Tow Hitch Install IMG_6996
Ford Bronco Tow Hitch Install IMG_6999
Ford Bronco Tow Hitch Install IMG_7004
swmetal
C8 vette
Interesting šŸ¤”. Didn’t even know they made one that goes behind bumper, don’t know if I really like it. Looks out of place
Looks like it would be very difficult to plug into the 4 pin part.
Guest
I agree, someone definitely modified that to fit there. I can tell by the almost 2 inches of bolt sticking out the other side lol.
