Transmission settings question
FleshTuxedo
A
PA
'22 OBX 2dr.
Hey all, I don't have my bronco yet, but have a couple questions about the settings for the Automatic transmission (did a search but couldn't find).
What setting do you use for everyday driving?
Say you put your Bronco into 4L and turn your Bronco off and then back on will it still be in 4L or will it revert back to whatever the stock/everyday setting is?
Thanks in advance, and sorry if this is a stupid question ;-)
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I know that if it's in Sport and you turn the vehicle off and turn it back on it'll go back to normal.
Designkid
Kris
New Jersey
2021 Bronco Badlands
If you manually select a transfer case option(4H, 4L, etc) it’ll keep that until you change it. If you select a different goat mode other then normal it’ll ask you if you want that mode again when you start the vehicle again. If you don’t say yes or no it’ll default back to normal
FleshTuxedo
FleshTuxedo
A
PA
'22 OBX 2dr.
So do y’all keep it in 2H or 4H for everyday driving?
MNbronco
RC
SE MN
2021 F150 Tremor, 2021 Bronco sport
FleshTuxedo
FleshTuxedo
A
PA
'22 OBX 2dr.
That’s what I figured, but wasn’t sure.
All my explorers I had were all 4H
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
No vehicle should ever default to 4 high, 2 high is normal driving, 4 auto for when you might have rain or snow.
FleshTuxedo
FleshTuxedo
A
PA
'22 OBX 2dr.
Right, using 4H on dry pavement can damage the drivetrain pretty quickly. 4H and 4L are for very slippery conditions
Oh, snap. What I meant to ask is if people use 4A as everyday setting, guess I’ll keep it at 2H.
I also just remembered that my explorer was auto/4H/4L.
Sorry. I’m very tired and my brain isn’t working right 😂
Mojave Lux
High Desert
Oh right, you're talking about AWD in other vehicles, similar to Bronco 4A. Yeah 4A can be used on dry pavement to some extent. I think there are problems with over-heating the transfer case if you run 4A too long at higher speeds. Like you said, dry pavement is basically 2H
RagnarKon
Ford Bronco, Escape, Focus
Yeah, everyday driving is 2-High.
4-Auto can be used on dry pavement... but it isn't necessary at all. If it is raining or the roads are slick, sure... use 4-Auto. If you want to drive a little sporty one day, yeah 4-Auto is fine. But if you are driving everyday in 4-Auto all you are really doing is negatively impacting your fuel economy and putting extra wear on your transfer case and driveline.
When it doubt use the GOAT modes, it automatically selects the appropriate transfer case setting based on what you select on the GOAT dial.
AZ_Liberty
2007 Expedition
Except... The Bronco treats Sport mode as a GOAT mode, and if you have the advanced 4x4 transfer case with 4A, it automatically selects 4A.
And Fords get their best MPG in sport mode, because it holds gears longer, so you use less boost.
FleshTuxedo
FleshTuxedo
A
PA
'22 OBX 2dr.
interesting!
RagnarKon
Depends how you drive it really. But... yeah... if you are heavy on the gas pedal you get better economy from Sport mode than Eco. If you aren't heavy on the gas pedal or are driving on the interstate, Eco wins the fuel economy race.
Switch it to sport mode and flip it back to 2-High. Win/win if you like to drive a little zippy around town. ;)
