Ive done some searching but cannot get a definitive answer. Does anyone know of a transmission skid that will work with the factory skids? Nothing fancy - just steel in my case. Appreciate the help.
Sure does, this is what I have!RCI works with OEM skids
https://rcimetalworks.com/product/transmission-skid-plate-19-present-bronco/
I'll second the LOD one. Easy to install and very solid.LOD works fineā¦I have an extra if anyone wants itā¦
If you plan to wheel over anything big: get the RCI cross-member skids and trans skid.2023 Wildtrak with cross braces. 2.7L engine.
So the best clearance skid that covers the v6 rails is LOD. Lot of people like to get the v6 rail covers and a center skid but the single piece design of LOD is better for sliding over things. I also like the the LOD skid is tied into the V6 rails adding strength vs a lot of other designs. I wish the LOD skid was slightly thicker but no one has junked one yet here locally(I will only recommend skids I have seen used to do real wheeling).2023 Wildtrak with cross braces. 2.7L engine.
