https://www.bronco6g.com/forum/atta...se-exterior-fabric-on-rear-window-pdf.379359/
Here is a link to a previous post with the TSB attached. Basically all the tabs have snapped off on the rear window, and I've taken that window out only a handful of times since owning the car. I suspect it would be covered by warranty.
The reason Im posting is because I phoned my local Ford Dealership and although they can't say if its covered until the car goes in, the rep told me that my VIN does not show this as being a recall and therefore because its not a recall associated to my exact vehicle it may not be covered. (This is in Canada)
Does this seem right? There's a TSB outlining an issue, I have the exact issue, and yet they're lining me up for bad news right away, as if it doesn't seem likely. Like its not a recall associated to my VIN therefore they can deem it as my fault rather than a manufacturer issue.
Has anybody here had the same issue, and were you able to get it covered? Thanks!
