Typical Lift for 35s?
weezy_jw
Houston
2018 F150 3.5L
So at the grocery store last night I saw a Wrangler Sport on 315/70-17s and it got me thinking that I have no idea about lifts on that Jeeps. Do you generally have to lift a wrangler to get it to 35s?
If you take your Sasquatched Bronco and park next fo a Wrangler on 35s, will it sit higher?
Would said Bronco look a little better with a slightly larger lift on 35s?
Advertisement
RG7
B8 A4
1: yes
2: depends on how much the Jeep is lifted
3: your preference.
Keep in mind that not all 35’s are created equal. Due to tread pattern, mfg specs etc 35’s from one brand might be closer to 34’s, while 35’s from another might be bigger than 35”
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
It’s tempting to use the Wrangler as an analogue for the Bronco when it comes to lifts and tire sizes, but the truth is it’s going to be to dependent on the vehicle type (clearance, esthetics, components) it’s not quite fair to try to figure things out now without a Bronco on our hands and without experience with the specific platform.
That said, here’s a video from Extreme Terrain talking about Jeep JK lifts, and what is necessary or looks the best with various tire sizes.
We can’t use it to figure out the Bronco, but it might help to put things in context for people new to these conversations.
weezy_jw
Houston
2018 F150 3.5L
  • Thread starter
  • Thread Starter
  • #4
I’m also very curious about upgrading my Sasquatch to 37s down the road. So I’m interested to see how much additional lift would be needed. Guy down the street has a rubi on 37s and it looks really good, so it’s tempting to show him up when the time comes 😂
Gamecock
2011 FJ Cruiser
I think that yellow prototype running 37s has 2" above Sasquatch...so that's probably a good estimate. It look sreally good with 37s; perfect amount of lift.
Felix808
SRV CA
waiting for 4door Badlands Bronco
Yep, it's not just 2" like most are thinking. If you order a 2" lift expecting that result you will be disappointed as the lift will be 2" above Base stock ;) .
Advertisement
Advertisement
