What lift to run 35s on Black Diamond Bronco?
MCVol85
Tennessee
Just purchased a black diamond 4dr and looking for some advice on what lift everyone has used to run 35s? Possibly looking at buying some stock wildtrak wheels to run on it.
MNBigfoot
MN
Sas is 1.1", I'd look you some take-off sets.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Ford Performance just came out with a lift and if I didn’t have SAS I would have gone that route
ブロンコ
Will
2022 | Black Diamond | 35-Inch M/T | 2-Door | 2.7
Dealer put 2 inch spacer lifts for 35s but I’m going to be changing those for the Ford Performance suspension which also gives it a 2 inch lift.
Evans67bro
Evan
Easton Maryland
2019 F250, 67Bronco,2022 BD,2023 BD
I had a 2" rough country spacer lift installed on my wife's 2022 black diamond removed the crash bars and installed a set of wildtrack wheels and tires. Looks great no rubbing and the tread is just inside the standard bronco flares. I am getting ready to do the exact same thing to my 2 door black Diamond.
Silence
SD
2022 Bronco
Bilstein 5100s. Less than $600 and a huge improvement in ride vs stock. That or sasquatch take-offs would be the path to take.
MCVol85
Tennessee
Ford Bronco What lift to run 35s on Black Diamond Bronco? 20220923_080514
Looks great, that’s the look I’m going for.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Hard to beat SAS takeoffs. Here is my old BD which i added SAS takeoffs and Wildtrack wheels/tires.
Ford Bronco What lift to run 35s on Black Diamond Bronco? PXL_20220212_170254598
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
My advice is go for substance, not looks. Spacers on Hitachis is lipstick on a pig. Get the best coilovers you can afford. The worst performing lift will look the same as the best performing lift.
TallDude
North Seattle
2022 4dr
So I am in the same predicament.
Want to get about 1-2 inches of lift.
Was thinking about the Ford Perf set up ($1700) or some SAS take offs ($500-1000).
But am leaning towards the Eibach set up ($1600), being able to adjust the height with added mods, seems like a great option.
Since I'll be paying to do the install either way, it's the same price no matter what I decide to put in.
Fordified1
Bob
Mid South Texas
If running the bilstein sas takeoff coilovers, does one need to get the sas upper control arms also? or are they the same.?
EDIT: Also, if I run the Ford Performance coilovers, that wouldn't void my warranty like an aftermarket lift might correct? For instance, if I kill an axle or diff.
Just picked my BD up last weekend.
Alabama
'24 Bronco 4 Door
Is this lifted at all? If not, any rubbing on your Black Diamond. Looks Great
