- Benjamin
- Apr 6, 2023
- 1
- 15
- 4
- Seattle, Washington
- 03 base bronco
- Base
Put the arb compressor in yesterday and tested everything, went for a drive and everything was kosher. Tried driving today, three miles from home and I get multiple codes
P033f - crankshaft/camshaft loss of sync
P061C - internal control module engine rpm performance
P06A6 - sensor reference voltage 'a' circuit range/ performance
U0401 - invalid data received ECM/PCM a
Checked all fuses and battery/ground connections everything is tight, pulled fuse from arb wiring loom to see if the compressor was causing some issue
Reset everything multiple times and codes keep coming back. Anyone have any idea what the issue might be, it starts slow and sometimes doesn't start at all.
Update,
Just got the vehicle back from the dealership wires under the dash needed to be spliced was rubbing from the factory I guess I have attached a photo of the service ticket in case this makes sense to anyone
Update,
