Is this ground on the correct side of the battery monitor module?2.7 attached are some photos of the wiring arrangement
I think there is battery monitor module connection on the ground side.
My bad. Good luck.It's a compressor not winch, never ran it without the engine running, switch panel is only active when engine is on so it can't activate anything without engine running
Grounds that I added are all now connected to the empty hole on the negative side of the battery terminal I would assume that that's is the correct side of this module but I could be wrongIs this ground on the correct side of the battery monitor module?
I have since disconnected everything assuming that whatever I did was causing the issue tried clearing codes and battery disconnect reset. Still having issues guess she is going to the shop tomorrowWithout looking it up, I'm assuming those 2 oem positive cables go to starter and alternator. I would have to look it up.
Do you mean fouled as in blew a fuse? Or in some other way that I wouldn't be able to check easily?Well you have fouled a fuse somewhere in the double deck fuse box.either top side or bottom side a fuse is fouled.
Do you know the wire or location so we can check our wires out for potential issues?This issue is fixed see update in first post
Only that they said the dash had to be removed and that the cables were for throttle, I don't think it would be an easy visual inspection service person said it was the first one she saw so it might not be a common issue, my vehicle only had 1700 miles on it so it happened pretty quickDo you know the wire or location so we can check our wires out for potential issues?
