- Jul 15, 2020
- 3
- 883
- 2,381
- New Mexico
- 2019 Explorer
- Badlands
Aftermarket will have more than enough choices. Don't let a factory roof rack hang you up.
painted trim piece comes with or without the rack. In your case you can add it later on, no difference.Maybe a dumb question, but should I order a roof rack even if I don't plan on using it? I'm not tall enough to really put anything on the roof without a ladder and would use a hitch mount for bikes, skis etc. But if I order straight from factory will I also get all the pre-painted trim pieces to remove the rack and install the extra trim? I assume it may be cheaper and easier to get the rack now and just save it in case I ever need it versus add it later on.
Great, thanks! I have a garage and half a basement full of car stuff I don't use or need on a regular basis (extra sets of wheels, spare parts I upgraded, etc.). Don't want to add to the pile if I don't have to!painted trim piece comes with or without the rack. In your case you can add it later on, no difference.
Sorry didn't read it that way. I would skip the Sasquatch. I had already decided that IF I was going with BL, no need for Sasquatch.Well my message was pretty clear it's either BL or BL Sas. You can't order the 4.7 gearing, it's a bug in the Build and price.
I'm looking into using the Tepui Foothill along with the Yakima small basket (Skinny warrior). Seems like a good solve for cargo and try for a 2drI saw a YouTube review. Looks good but it would be nice to hear more. As far it's only the option (good option) for Bronco.
thanks, will check it out. The biggest limitation is the dynamic load.I'm looking into using the Tepui Foothill along with the Yakima small basket (Skinny warrior). Seems like a good solve for cargo and try for a 2dr
Yea the Foothill comes in at 110lbs already, but I’m also worried about the footprint of the Superlights because from the render, it fits the 4dr betterthanks, will check it out. The biggest limitation is the dynamic load.
Yeah. But the tent is 110 lbs and it's maximum already. Right?Yea the Foothill comes in at 110lbs already, but I’m also worried about the footprint of the Superlights because from the render, it fits the 4dr better
oh yea, youre right. The dynamic rating is 110 for the current roof rack..Yeah. But the tent is 110 lbs and it's maximum already. Right?
