Slumpbuster
andrew
SOCAL
1977 Bronco, 1995 Bronco.. 2005 Jeep LJ Rubi
I'm wondering if that was a hill decent control test or something of the sort on the way back down. I would be pretty sure if it were an auto trans.
Advertisement
Jimbogee
Jimmy
TX
Ford F350
I used to have an 08 JK that struggled to even back up my driveway. From what I remember reading back then, Wranglers struggle to go up hills in reverse. Maybe they are demonstrating that the Bronco does not share that problem.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
On the way down rear wheel lock then front wheel lock, must have been some auto pilot.
I think if it were me at the wheel it would be all weight on brake, solid panic try and hold.
Very impressive.
They were probably trying to demonstrate the practical benefits of the 95:1 crawl ratio of the manual transmission, which theoretically generates 29,000 lb-ft of torque to the wheels.
https://www.hagerty.com/media/news/the-new-broncos-crawler-gear-ratio-is-seriously-impressive/
PDiddy
Paul
4Runner
Very impressive.
The trail assist modes do a really good job descending. I stopped going down steep stuff in my 4Runner without the assist. I can’t break one wheel at a time to keep the vehicle straight or on path. The assist can, and it does a fantastic job of it. So instead of a stead slide down the hill, I maintain traction all the way down. Not sure if this manual one has something similar.
Broncofly
Paulo
North of the Columbia River
Subaru, Honda Africa Twin, Husqvarna 310R
2.3L Bronco with manual transmission goes reverse up Hummer Hill (37 degree incline) at Moab. Thanks to @Freewheelin_overland on Instagram, he’s been the main source of These Moab videos!
Annnnd.......another........"Hold My Beer' feature.?:cool:(y)
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
That is a pretty steep ascent & is rather impressive. You will never be able to climb complete vertical so as the grade gets steeper it is harder to get enough traction as the suspension unloads, to pull the vehicle up, you just end up spinning wheels regardless of being locked on all 4 corners. The reason he only goes part way up is because the trail flattens out & the obstacle has been overcome. Take note that this is a steady crawl and not a gas it bomb run (less momentum more traction needed).
It is 80%, 90 % front axle due to weight shift - comfortable on the way home IRS front axel.
Fotoflyer
William
Yuma County, Arizona
Lifted 2007 Nissan XTerra Off Road (Overlander)
crazy how simple this looks for it. I can’t imagine taking my f150 through that little exercise at all.
To people who would know, is this common at this hill at Moab? To reverse up the hill only to crawl down?
Particularly steep hills are often conquered by reversing up the hill, because the engine and transmission are located ahead of the centerline of a normally rear drive vehicle. When facing Uphill, the majority of the weight is centered over the front of the vehicle, unloading the rear end, which cannot contribute as much energy (torque) to the climb. By facing backwards, you put more weight towards the rear of the direction of travel. That can provide a significant advantage.
CanadianHorseMan
Rob
Toronto, Canada
2017 Shelby GT350R || 2019 Golf R
Vehicle Showcase
That’s pretty impressive, but do you think it can match this?
That’s impressive but it would have been better if the guy had the horizon straight.
Id say the horizon is on about a 35° angle...I had tilt my phone to make it straight...so who knows what the angle actually is...
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Vehicle Showcase
Advertisement
Advertisement
