What do you think about this tires?
truckatologist
Cam
Grand Rapids, Michigan
2022 4 dr 7MT, on order
They look quiet- how much do they weigh per tire ? What brand and size ?
CT203
Connecticut
'13 JK
What are they? It looks like they’ll be good road tires, should be fairly quiet. They will not be good off road however. That’s fine of course.
Oden502
Khalid
Qatar
Bronco wildtrak
Actually I am using Yokohama Geolander 285/75R17 and I took this tires from a friend to try it on the Bronco.
Beachin 74
Delaware
They would be perfect on the beach. (y)
filup01
‘21 F-150
The emblem looks like a Wildtrack but it's not a squatch. Do the export Wildtracks not get the squatch treatment? If it is a Wildtrack, why did you put on city shoes?
Also, by the looks of the dust in the middle of the tire, it appears you have your rear tires over inflated. To answer your question though ("what do you think"), you know what you did was wrong. Go put real tires on that Bronco.
I'm not being mean. You asked our opinion. In my opinion, you should fix it.
Wanted33
Down south in Dixie
Khalid, if you like them I do too. They do look like a nice set of highway tires, and probably a lot quieter. Honestly, I think they look fine.
broadicustomworks
Hanging Rock, North Carolina
I agree they are overinflated due to the pattern you see just in the center section of the tread.
I also agree that they would provide a smooth, quiet ride on pavement.
And very nice courtyard tile.
Jawbox
Greg
Crookston, MN
Bronco 4 Door
I think it makes sense to buy the tire that fits how and where you use the Vehicle. I believe in function over form. My only concern was the way the dust was leaving a pattern that indicated the center was bulging out, thus over inflation.
You should try to have an even pattern across the tire generally for even wear. If you want less surface on the road, buy a narrower tire.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
They look like tires meant for a trailer. Are the passenger vehicle tires? Maybe double check!
