What I Wish Someone Made/Sold for the Bronco; What Else Would You Want?
WILDcardOD
Patrick
SW Michigan
Rav4, Bronco on the way
I want a soft rear tonneau cover that doesn't strap over the tailgate and can be used with reclining rear seats.
I second this. I ordered it not knowing it worked like that. I kind of want to cut the straps off and sew some strong magnets on. The magnets on my Jtop are amazing. Actually @JTopsUSA can you just make a nice tonneau cover lol it would go great with my Bimini top.
Ford Bronco What I Wish Someone Made/Sold for the Bronco;  What Else Would You Want? IMG_6342
l88m22vette
IL
Please sir may I have locking diffs?
^ Magnets won't work since its aluminum
fordtruck76_390
1975 F250 4x4 Highboy
I’d like to see some sort of cross bar so that I could drive with the rear cap of the 2-door off, but still have the front 2 panels sturdily in place. For more of a late 70s on, full-size Bronco look.
Browp24
Paul
Hudson Valley, NY
2021 bronco
Wish there was a Bimini top that was tight when installed, had access holes/zippers to take off hard top, had NO Velcro that I have to put on my roll bars, and no gap near the windshield. I feel there are none that tick all those boxes.
And a larger fuel tank.
I don't have a hard top but have the sun shade from Dirty Dog. It has straps you pull for the shade to tighten up. Not sure if this is what you are looking for or if you have a 4 door, but I would recommend.
https://store.dirtydog4x4.com/?route=product/product&path=62_149&product_id=638
Broncobren
Matt
WT High Pkg MIC Mod Bumper
dangerzone79
O- -O
Bat Country
2022 Black Diamond & 1972 Bronco
I would REALLY like a molle cargo system designed for the 4 door. Every one I see is made for soft top only. The bottom/sides work but not the top/window pieces.
So... why exactly does this not fit on a hardtop? Anyone know?
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Gun scabbard mounts for the roll bar....
Driver's side tunnel MOLLE panel that is no-drill
Felix808
SRV CA
I’ll go ahead and add. Lower gears for the t case. Something in the 4-1 to 5-1 range.
Along this line of having the ability to run an Atlas with zero alarms/ lights on the dash 🤠
Mdsuits
05 f350, 68 bronco 89 samurai
That would be a nice option as well.
7sKnuckledragger
Southern California
2002 TJ, 1978 K5, 2007.5 Ram 2500, 2022 F150
A naturally aspirated engine option, floating rear end, solid knuckles and stronger steering gear. A frame supported rear tire carrier and a roll down back window. A factory option to eliminate trail sights and delete the A.S.S. And cup holders.... just a few ideas
Gnomad
Harbor Springs
Base 2 dr, 7MT EG
https://www.bronco6g.com/forum/attachments/jeeptop-jpg.547199/
This, for a 2 door, and without the folding part in the front. Set up so I can use the freedom panels on the front and fold down the back for an open feel and then easy to fold back, install the panels and hit the freeway or be prepared for unexpected precipitation.
widnere12
Georgia
I wish even 10% of the Bronco accessories didnt say "Fits 2021-2023 Bronco (Raptor Excluded)". My raptor needs some accessory lovin too.
