What offset are you running?
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
KMC Recon 17x9 -12 Offset 285 70 17 More poke than I intended/wanted but I like the stance.
Ford Bronco What offset are you running? 20220507_112726
Jhuff
J
Toyota Tacoma and DR650
I’m looking at fuel trophy wheels with +6 offset. Worried they may stick out to far. Bronco I have ordered is a 4 door bigbend will be adding 2 inch lift. Any thoughts??
I have Fuel Vectors with +07 offset and 35x10.5 Kenda RTs. With my Sasquatch flares, I have good tread coverage, but the sidewalls do poke a bit and could sling crud.
Ford Bronco What offset are you running? 20220524_181113
Ford Bronco What offset are you running? 20220524_181102
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
Do you have any additional pics? Im interested in the flares. Do they stick out farther than the stock Sasquatch flares? With my 17x8.5 0 offset Im about an inch past the stock Sasquatch flares.
They do, by about an inch. The flares were right out of the Ford Accessories catalog:
Ford Bronco What offset are you running? 1658835390043
Here's a couple of other pics. Of note, I recently replaced the wheels/tires. Went with the same wheel but in a 17x9 along with a 315/70x17 BFG KO2. The wheels are +1 offset and with this wheel/tire package they come right to the edge of the flares. These pics were with the original wheels/tires on the Bronco when I purchased it. I was also incorrect on my original post. The Fuel Blitz that were on there (the ones shown in all the pics here) were actually 20x10 as opposed to 20x9 as reported by the dealership. They were -18 as opposed to +1 on the offset. Sorry for any confusion.
Ford Bronco What offset are you running? 1658835609962
Ford Bronco What offset are you running? 1658835723192
MikeyM
Savannah, GA
2022 F250 King Ranch Carli 3.5" & 37s
17x8.5 with 0mm offset or 4.75" backspace
Ford Bronco What offset are you running? 292547824_2329320383876334_2861376939848112241_n
Lucky13!
jeff
Charlotte
Ford Flex
17x8.5 +25 Method 305, Sas flares. Minimal poke.
Wow, those look a lot more like a zero offset than a +25 (w/SAS flares) Looks almost exactly like MikeyM's rig two posts below but should be 1 inch sucked in from where he is. Poke is a weird beast.
mcinfantry
Lee
Louisiana
Badlands 2 door
Any tailgate flex With the kenda??
Jhuff
J
Nothing that I've noticed so far, mainly from leaning on it, but I'm not watching it when hitting bumps and such.
The weight of the vectors+Kenda's is the same as OEM Squatch takeoffs, but the offset prevents the rubber bumpers from supporting the tire. I purchased some longer bumpers but haven't been worried enough to install them yet.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I just bought some racquet balls from Amazon, loosened up the tire to seat them, and tightened back down. A bit easier than swapping out the stops.
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
My 17x9-12 stick out just a little on my sas.
