Yes. 6x139.7 (6x5.5)I really want to know exactly what backspacing's and offsets work with the Bronco. Such as max + and max - just so when I look at wheels I know what range I need to look at and know what will work and what won't work. I am going to stay in the 17inch range. And the bolt pattern is 6x5.5 correct?
Your offset value changes, depending on the Rim width that you select. Think of this as a secondary concern.
Your Backspace is more important, now and later, as aftermarket parts, like UCA's require different amount of backspace to fit the component properly. Just for sample, I offer the following:
8.5" wheels, with a "0" offset -- typically have a 4.75" backspace.
9" wheels, with a "0" offset -- typically have a 5" backspace.
9.5" wheels, with a "0" offset -- typically have a 5.25" backspace.
The reason that I used "0" offset in my examples, is because the builds that I have seen on this and other sites, claiming to have a "0" offset looks about bright to me, if they also run the Sasquatch (wider) fender. Yes, each one will move your wheel in or out, by a 1/4"... so it becomes a choice of the way you like it to look (5.25" is tucked in a little bit more. 4.75" is pushed out past the fender flare a little bit more.
