Interested in how many of my Bronco sister(s) and brother(s) out there that have pull the factory wheel and/or Tires and upgrade to 37" or bigger.
There is like two Suv's in production that have higher ground clearance than a Bronco Sas, and one has it beat by 2/10s of an inch. The 2003 GC had a measly 8.7" of clearance.The biggest challenge with the Bronco is that even with SAS the overall ground clearance isn't that great. My 2003 Grand Cherokee with a 3" lift and 31s had the same breakover angle as this SAS Bronco so for me a small lift and 37s was the only way to get the clearance I need for snow wheeling, big ruts, etc. Older Jeeps with smaller tires and a small lift have much better overall clearance. The only issue I had with my Jeep was getting stuck on the diffs which the 35s on the Bronco definitely help with.
Yep exactly, so with 3" lift and 31s I gained about 3.5" on top of that 8.7 which left me just over 12" ground clearance if you don't count the diffs.There is like two Suv's in production that have higher ground clearance than a Bronco Sas, and one has it beat by 2/10s of an inch. The 2003 GC had a measly 8.7" of clearance.
I was in the same boat as a former XJ owner. 4 1/2" lift & 32's took me everywhere the YJ's, TJ's & JK's on 35's were going.The biggest challenge with the Bronco is that even with SAS the overall ground clearance isn't that great. My 2003 Grand Cherokee with a 3" lift and 31s had the same breakover angle as this SAS Bronco so for me a small lift and 37s was the only way to get the clearance I need for snow wheeling, big ruts, etc. Older Jeeps with smaller tires and a small lift have much better overall clearance. The only issue I had with my Jeep was getting stuck on the diffs which the 35s on the Bronco definitely help with.
