Wheel and Tire Swap Question for OBX 2.7L 3.73 Gear Ratio
Tteape0
T
2022 Ford Bronco Outer Banks 4 Dr
I have an OBX 2.7L 3.73 gear ratio. I do mostly road driving with very light off roading for camping. I plan to install the ford performance tuner and ford performance 2” lift kit before I swap wheels and tires. Will I have any issues to be aware of swapping my 32” OBX wheels to some SAS or WT take offs? Will this effect me at highway speeds (75-80 mph) with the extra 45hp and 30 lbs of torque from the tuner? Are there any long term suspension issues I should worry about and other things I need to plan for on the swap? Will putting SAS or WT take offs void my warranty since the lift kit is covered by ford?
Edit : would the extra 20 lbs per wheel and tire stress anything too much if I have a roof tent as well?
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
With the 3.73 I honestly would go with 33’s rather than 35’s. Is it doable, yes but a C rated 33 (285/70/17) would ride a bit better, be nicer to your mpg, fit on the tire carrier with no modifications. That is the stock size on the Badlands. Also they actually fit without a lift with the correct offset. That being said, I love the look of 35’s too 😂
It won’t be too bad on the highway. You will lose some pep but your not racing anyway. No long term effect on suspension, but gearing could be an issue way down the road if you go with a heavy E rated tire as it will stress the gearing over time.
I thought with the 2.7 gearing was upgraded to 4.46?
This is the Wife’s 2.3 OBX 3.73, 1” Level, 33’s with 17x8 +18 Outlaws. Setup fits without removing the crash bars.
Ford Bronco Wheel and Tire Swap Question for OBX 2.7L 3.73 Gear Ratio B2434CF7-30E9-46F3-B908-3BAE94B0AA4C
Tteape0
Tteape0
T
Thanks for the info but it didn’t really answer my question too much. I thought stock SAS wheels and tires were pretty light weight (only 20lbs more per wheel and tire than outer banks stock). I would stick with the ford stock tires so I don’t think weight will be an issue, unless I am misinformed about SAS wheel and tires weight.
I’m also not worried about lose of pep and power as the ford tuner adds 45 hp and 30 lbs of torque with a better gear shift patterns.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
You'll be perfectly fine. They fit and look great. Good luck!
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
Something to consider is that those torque and hp figures are at RPMs that you’ll seldom reach in everyday driving. Especially with the 3.73 gears.
Just saying that the Ford Performance tune is not a fix(or even much of a help)for on “over-tired” situation.
Tteape0
Tteape0
T
Just saying that the Ford Performance add is not a fix(or even much of a help)for on “over-tired” situation.
Do you think it’ll be “overtired” with the extra 100 lbs difference from the wheels? Any way to prevent this beside regearing?
AMTRV
Oliver
If you stay with no larger than 33”s I don’t believe weight will matter a whole lot. Most 285 70 17s won’t be much heavier than your stock tires and they‘ll look great. Most have actual diameters of 32.8”.
The 3.73 ratio axles a really a good all-around axle ratio.
Just don’t get crazy with tire size and weights.
I‘ve seen the 285s do everything the 315s will do off-road…..literally
Spooled
Republic of Texas
A tune doesn't magically cancel out being undergeared. It's only going to help when you're accelerating. The quoted gains are only at full throttle and are peak numbers. That being said, if you just had to do it, sasquatch takeoffs is the way to go since they are a light tire for being a 315/70 size.
prospectfour
Pete
NJ
'22 Bronco, '18 Tiguan
Good advice, don’t get hung up on having 35’s. Sure you could make it work, but the 33’s will make your live easier and look damn good too.
RADRide
Rich
Sayville, NY
@derichio02 did you see any hit to mpg or performance I'm looking at a very similar set up inwheel/tire weight
derichio02
Bo
Southern California
Lost about 1-2mpg initially but got better once after break in of 2k miles. Make sure your tires are Load C rated the tire store tried to vive me Load E initially in the exact same size.
