Whipple Intercooler install problem on Bronco Raptor 3.0L
Quick
CT
23 Bronco Raptor
I installed the Whipple Megacooler today and ran into an issue. I wanted to see if anyone else ran into this problem.
There is a step which requires installing the plastic shutters from the back of the intercooler onto the new intercooler. I ran into a problem at this point. On one side of the intercooler, the welded on brackets appeared to be in the wrong place, about an inch lower than the factory plastic piece.
I proceeded with the install without the shutters, and have an email into Whipple, but wanted to check the forums to see if anyone else experienced this.
Ford Bronco Whipple Intercooler install problem on Bronco Raptor 3.0L IMG_8501
Ford Bronco Whipple Intercooler install problem on Bronco Raptor 3.0L IMG_8502
Ford Bronco Whipple Intercooler install problem on Bronco Raptor 3.0L IMG_8503
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
From what I have seen of installing the Whipple intercooler, that bracket was to move the shutter motor to the bracket. The Whipple is to big to have the shutters fit. At least that is the way I have seen it done on a non Braptor, which I thought was nearly the same for the Braptor.
Quick
Quick
CT
23 Bronco Raptor
You're referring to the shutters on the front, which were removed. These are passive shutters on the rear of the intercooler. They form a tunnel up into the radiator fan intake, to presumably pull cool air through the intercooler at idle.
Ninjak
Miami
Ahh, I see. Thanks for the clarification.
bwilly68
Cleveland
Chevy Tahoe, Land Rover Defender
I had the same problem installing the whipple in my raptor bronco. Could only get three of the four brackets to line up on that rear bracket. Whipples answer was that they leave the rear shutters off as well. Not sure why they bothered to put the screw hole and hooks on their intercooler or why they haven’t fixed the design yet. I installed their cooler 8 months ago and sent them photos of the problem. I cut some material off the shutters to try to get it to sit down as much as possible and then ended up putting a heavy zip tie on the corner with the hook like in your picture. It is holding up fine after 4000 miles. If it ever fails I may just pull the rear shutters off.
Ford Bronco Whipple Intercooler install problem on Bronco Raptor 3.0L 1705286214425
Ford Bronco Whipple Intercooler install problem on Bronco Raptor 3.0L 1705286097373
