Will you get front license plate installed at dealer?
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Just found out from my dealer that the front license plate bracket is installed at the factory. So if it's on your order then it gets installed whether you like it or not. I thought it was a dealer installed item. The bracket is on my order which has been scheduled. Now I guess I'm stuck with it. I'm super unhappy about this. Check your orders and make sure the bracket isn't on there!
On other vehicles it is installed at the Dealer. I asked my Dealer and they said it comes in a pkg. and they install it. It is in my sales agreement to not install it.
SPS4
Sean
Audi S4
I have front licence plate bracket in the order preview.
Do you think the factory is the one who will install this?
That's what my dealer is saying. Others are saying different. I had my dealer remove it from my order just to be safe. I hope it's not too late though, because I already have a VIN.
acnp2022
CT
ford
Will you get a front license plate install by default?
I don't like the default location installed by the Ford.
Is that possible to put this into the build note?
Will it be easy to move the front license plate later?
Or there will be a marking drill leftover
When I knew my bronco had shipped out I told my dealer not to install the front license plate and they did not. I did not want any kind of holes. I just put it on myself. Still holding on strong
Ford Bronco Will you get front license plate installed at dealer? 20E64038-C680-47EE-A333-250AC8A95678
Rahkmalla
NJ
15 K900
Back when I used to sell Fords, the front plate bracket was a PDI installation item. The only time I was ever instructed to tell customers that it was factory installed is when I had a customer from a neighboring no-front-plate-state order an MKS, and the mechanic installed the front plate bracket anyway after being specifically told not to 3 times.
HotLap
Bradley
CA Central Coast
2018 Ford Raptor and 2019 Yamaha XSR900
No, the huge sheet metal screws they use to mount plate bracket will seriously damage your front panel paint, and when installed with a speed tool it will deform (pull up) the plastic around the hole making it very hard to repair…
