Has anyone else had this issue before?
I was coming home from a 6+ hr road trip with high wind speeds on the freeway and my driver side window started popping out of the seal on the top outer edges and rattling on my 2dr bronco. Crazy wind noise. I pulled over a few times to pop it back inside but it kept malfunctioning.
Solution: I read somewhere about a reset you can do that will have the car relearn the correct window height/seating. Press auto window down all the way, after its completely down hold the down button for 5 seconds, auto roll up, hold up for 5 seconds. Repeat this process until you can see the window seated correctly from the outside. I also opened and closed my driver door during this process.
Hope this can help someone out.
